John Deere Starter/Generator
this thread has 6 replies and has been viewed 466 times
Old 08-18-2019, 06:59:06 PM
labans labans is offline
Default John Deere Starter/Generator
Hoping I am not too far off-brand here as I am Onan owner.
But I have a stumping problem with a John Deere starter/generator that is driving me nuts. I bought this S/G new and when it arrived I bench tested it and it motored just fine. But when I install it, it will start the engine but nothing I do will get it to charge. Also installed new electronic voltage regulator. I tried to see if I could get it to give full charging output but am not sure what to do to achieve that because I don't really understand the wiring on the unit.
I would appreciate help with proving that this new unit will charge with the engine running---or not. I need a foolproof test.
Photos attached.
All help appreciated.
ID:	341717   Click image for larger version
Old 08-24-2019, 10:55:34 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: John Deere Starter/Generator
John Deere builds many things, they've also bought and rebranded many things, everything from big construction machines down to chain saws.
Perhaps you'd find more response if you were to identify the type of machine, and it's model number and vintage, as the information you've provided is clearly insufficient.
Starter Generators came on a whole lotta stuff, and while they all have certain characteristics, making them operate in the motoring circumstance is easy, making them generate requires external circuitry... a regulation system which provides a field supply, and requires a ground return, and depending on wether that regulator is in the source or sink side, will work entirely opposite. Clearly, if your starter-generator motors, then the lack of output is a result of incomplete operation or misconnection of the external controls.
Old 08-25-2019, 07:47:29 PM
Thank you for the reply. I was nervous about any more information about the unit so as not to get knocked off the forum or have people ignore the posting.
The starter\generator is off of a John Deere 2003 Turf Gator TX.
It is a single cylinder engine and uses a sliding-cone and pulley transmission. It has a solid state 3 wire regulator with red\green\black. The red\green come from the generator through a two-wire plug that is labeled DF. There is the large red wire coming from the starter solenoid to post F2 on the starter. A2 with black wire is ground. Then a wire connects F1 and A1 together. When running I have battery voltage at the F1 post and solid ground at A2. I don't know what the F1 and A1 being connected are all about. The red and green wires, when running are at 0 voltage. I am just stumped at how to make this generator generate. It seems that I should be able to run the engine and then manually force the generator to generate, but I don't know the correct procedure. Any help is appreciated.
Old 08-25-2019, 11:45:31 PM
Ken Karrow Ken Karrow is offline
If no one comes up with definite answer you might check with JD for service manual. JD sometimes can furnish manuals on quite old equipment. A few years ago I bought service manuals on a 1966 garden tractor.
Old 08-26-2019, 01:03:57 PM
landreo landreo is offline
I do not have one of these gators so take anything I say with a grain of salt.
These SG have separate outputs for the armature, starter or series field, and one set for the regulator or shunt field. That is why there are terminals A1 and A2 for each side of the armature and F1, F2 for each side of the starter field. The red and green wires should be for the shunt field. These can be wired up to reverse the rotation which is the reason for all the separate terminals. The output is typically through the starter solenoid and it must stay closed to feed current to the battery. If the starter solenoid does not stay closed while running then it will not charge. The regulator has to have 12 volts going to it to energize the shunt field. The red wire should have some amount of voltage when the engine is running.
F1 and A1 normally would be connected internally on most SG but they are just externalized to allow for reversing the direction.
The best way to test is while installed in the gator. The F2 post should be at battery voltage when running.
A photo of the starter solenoid and regulator would help.
Old 08-26-2019, 08:35:45 PM
eMail NOT Working
That looks pretty darned similar to the Kawasaki FE290 found in a Club Car golf cart a couple weeks ago.
I would not be surprised if that's the same starter-generator setup found in 2-stroke golf carts that use direct-reversing (meaning, it starts the engine in forward, and when you flip the reversing lever, it starts the engine in the OTHER direction).
JD is really good about dissolving as much information that would cross-reference supplier's product and parts with their own, so that they retain the single-source for parts for their machinery. End result is that you pay very Deere'ly for that green paint.
What is a Suitable Replacement for a John Deere M Starter and Generator hitmissfan Antique Farm Tractors 4 07-04-2018 10:37:15 PM
John Deere LUC starter RLindley Antique Farm Tractors 3 01-12-2013 09:58:39 PM
Help With John Deere 317 Starter... KenS999 Garden Tractors and Mowers 12 11-01-2011 09:44:47 AM
John Deere LA Starter Issue Lvolling Antique Farm Tractors 1 08-11-2011 01:22:26 AM
John Deere 620 Starter Problem patrickingalls Antique Farm Tractors 3 02-19-2011 04:14:03 PM
