Briggs/Sears washer motor - What is it?
this thread has 12 replies and has been viewed 2580 times
Old 04-14-2009, 06:40:01 PM
Zira Zira is offline
Photo Briggs/Sears washer motor - What is it?
Picked this up last week. I am sure it is really a Briggs but I don't know much about them. What model is it, what should it have for a gas tank, was there a kick start on it originally? I am surprised by the stamped metal base & the big crank case breather.
ID:	52299   Click image for larger version
Old 04-14-2009, 06:56:42 PM
Bob Kurtz Bob Kurtz is offline
Default Re: Briggs/Sears washer motor - What is it?
I would say most likely an early Briggs WMB, and was probably on a washing machine. My 2 cents.
Bob
Old 04-14-2009, 07:39:02 PM
K D Redd K D Redd is offline
I concur, a WMB. Post the type number as I can I.D. for sure from the parts books I have. I have one just like it with the same exhaust manifold and LITTLE VACU-JET carb with no provision for an air cleaner.
Kent
Old 04-14-2009, 07:50:12 PM
hitnmiss hitnmiss is offline
Quick way of identifiying. If the spark plug is verticle, in the top centre of the head, its a WMB.
if the spark plug is horizontal, in the edge of the head, just over the carburator, its a WM
Old 04-15-2009, 06:18:51 AM
Leonard Keifer Leonard Keifer is offline
Except I've had a WMB with the horizontal spark plug.
Old 04-15-2009, 08:45:10 AM
The head has been changed or the data tag is not the original to the engine.
Kent
Briggs /Sears Roebuck ID DaveHC Small Air Cooled Gasoline Engines 2 06-12-2009 02:32:07 PM
Need help finding parts for Sears motor Dwight S Small Air Cooled Gasoline Engines 4 03-09-2008 08:02:05 PM
Sears radial arm saw motor 6hpMarty Generators & Electric Motors General Discussion 2 01-08-2005 04:28:16 PM
Sears Tag on a Briggs? Dan Bogart Antique Engine Archives 3 06-14-2003 03:34:38 AM
sears/briggs charlie frayer Antique Engine Archives 1 06-10-2001 09:29:34 AM
