Three Engines, what are they?
this thread has 36 replies and has been viewed 4607 times
Old 12-23-2010, 03:27:41 PM
QuickJ QuickJ is online now
Default Three Engines, what are they?
And what would be a reasonable price?
These three engines are coming up in a live auction in a couple of days. The only description in the auction catalog is "antique engine" .
Can anyone tell from the photos what they are, and give an idea of what would be a reasonable price to bid.
Thanks in Advance.
ID:	96065   Click image for larger version
ID:	96066   Click image for larger version
The Following User Says Thank You to QuickJ For This Post:
Old 12-23-2010, 03:30:54 PM
KyleBlankenship's Avatar
KyleBlankenship KyleBlankenship is offline
Default Re: 3 engines, what are they?
the first one looks to be a fairbanks z style d, the second, a briggs, and the third look like a economy. good luck at the sale!
The Following User Says Thank You to KyleBlankenship For This Post:
Old 12-23-2010, 03:32:59 PM
check that, the second kinda looks like a kohler...
Old 12-23-2010, 03:39:58 PM
Phil P Phil P is offline
I would say #2 is an AEH Wisconsin.
Phil P
Old 12-23-2010, 04:41:18 PM
Farmboy1 Farmboy1 is offline
i would say Phil is right look at the cranks on top of the engine those are correct for that model area.
Old 12-23-2010, 04:59:29 PM
Hi
Look at the plate bolted to the crankcase behind the magneto (you are looking at the back of the engine). This indicates a base mount magneto. The size of the air cleaner indicates the smaller of this model group (AAH, AEH, AGH etc.) Although the shape of the gas tank indicates a larger and newer engine like the AGN but the AGN doesn’t use a base mount magneto. All of these have the cylinder that bolts to the crankcase.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 12-23-2010, 03:32:45 PM
Mike O's Avatar
Mike O Mike O is offline
#1 is a Fairbanks Morse ZD. $150.00 - $200.00
#2 Briggs type weather it is a Briggs, Lausen, Wisconsen??? $20.00 - $50.00
#3 Economy / Hercules I just sold a couple for $350.00 each and they went straight away so I was a bit low but certainty under $500.00! Good luck
The Following 2 Users Say Thank You to Mike O For This Post:
Old 12-23-2010, 06:16:14 PM
Gilbert_Bates Gilbert_Bates is offline
Well you know how auctions are.
Heading into this auction and how bad I wanted it, Mike is about right on the ZD, I would value the pump at $50-$150. I'll bet this setup will go for around $250.
No comment on the Briggs
About $500 for the Economy / Hercules is about right at auction, if it is all there. If they demonstrate it to run add another $100 or so.
Again this is the auction mentality where anything can happen.
Old 12-23-2010, 06:50:44 PM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is offline
Default Re: Three Engines, what are they?
The Hercules has the new style Webster mag .... not always a good thing.
In Kennebunk, Maine;
Doug Kimball
Old 12-23-2010, 07:41:10 PM
There are two easy ways to determine if it is an AGN. Unfortunately the picture is not oriented in a way to tell for sure. The AGN didn’t have an inspection cover on the block on the gas tank side and didn’t have a base mount magneto. My AEH parts book shows a fuel tank like the AGN tank was available. I have to old “Brown Cover” parts and service manual.
Phil P
Old 12-23-2010, 11:10:18 PM
Zira Zira is offline
I'm with Curtis on the middle one. Exhaust screws directly into the block rather than a manifold like the ADH/AEH or AFH/AGH/AHH. Cylinder jug bolts onto the lower end, unlike the AENL. Wouldn't expect it to be crank start though. gas tank also matches AGN,
Good Engines and Bad Engines Mark Thompson Steam Stationary Engines, Traction Engines 75 11-27-2009 08:45:32 PM
