Go Back   SmokStak > SmokStak® Support and Information > How to use this web site:
How to use this web site: Registering, passwords, navigating, subscribing and getting the most out of this web site.
Dial-up users: speed up screen displays...
this thread has 0 replies and has been viewed 14599 times
Old 09-11-2005, 05:09:33 PM
Default Dial-up users: speed up screen displays...
Enginads or Smokstak: On the main index page. If there are sections that you've already seen or don't need, there is an up/down arrow or a +/- over at the right side of the separator bars. Click that and you will expand or shrink that particular section, saving the download time for that section.
Smokstak: go to: UserCP (SETTINGS) > Edit Options > Thread Display Options > and uncheck Show Images (including attached images and images in [IMG] code.) Doing so will cause all attachments to be represented as clickable links rather than images. The only time you will wait for a photo to show is when you click one. You can also unclick "Show Avatars" and "Show Signatures" at the thread display options section of your control panel.
-- Harry
Lathe Thread Dial Dave Richards Machine Shop and Tool Talk 11 07-20-2014 07:48:44 PM
The Dial Engine Bundy Bear Hit & Miss Gas Engine Discussion 0 07-01-2014 11:58:18 PM
Dial - Galloway Engine Bundy Bear Hit & Miss Gas Engine Discussion 9 07-25-2009 07:29:39 PM
Dial up answering services Cody C Computer, Camera and ISP Problems 0 03-12-2008 05:16:11 PM
