Wisconsins and Lincoln, loads of engines, welders and generators
this thread has 7 replies and has been viewed 1737 times
Old 11-21-2012, 09:06:01 AM
Thiel's Avatar
Thiel Thiel is offline
Default Wisconsins and Lincoln, loads of engines, welders and generators
I don't know what got into me. I guess seeing old iron makes make dizzy.
Just cleared out a patio in a local subdivision. Besides many small briggs and wisconsins I unearthed a Lincoln welder with Wisconsin Twin(180DC), a Marquette Welder, a Hobart welder. 2x V4 Wisconsins with massive Generators attached to it and a V2 American Marc AC2 Diesel. The Diesel is supposedly stuck, so I may bring them straight to the scrapper since parts and support seems iffy (at least when reading previous posts). The Twin Wisconsin with the Lincoln I may get going, and if I don't electrocute myself
I'll keep you posted. Geez and I wanted to stay away from the heavy stuff
Thomas
Name:	3 big ones.jpg
ID:	150018   Click image for larger version
ID:	150019   Click image for larger version
Old 11-21-2012, 12:01:57 PM
Default Re: Wisconsins and Lincoln, loads of engines, welders and generators
That'll keep you busy for a while!
Please list anything you onsider "dump" material before you take it. Most of this stuff is no longer available.
The Following User Says Thank You to Jim Rankin For This Post:
Old 11-21-2012, 12:40:55 PM
Ironsides Ironsides is offline
Thiel,I wish I lived closer to you that 2 cylinder welder is a real find I used to use one welding broken dozers and machinery in SW West Australia.Don't let the ignition switch trick you out is stop in is run.If you need a good welder that will just keep plugging along you now have one,keep cranking,Norm
The Following User Says Thank You to Ironsides For This Post:
Old 11-21-2012, 05:56:12 PM
dave robertson dave robertson is offline
hi tom id save that american marc ac2 diesel there are hard 2 find sell it 2 some 1 to restore i have a 1 cyl thank you dave
The Following User Says Thank You to dave robertson For This Post:
Old 11-21-2012, 07:01:48 PM
RSCurtis RSCurtis is offline
I would save everything in the pictures.
Old 11-21-2012, 07:25:14 PM
Nice haul.
Old 11-21-2012, 07:33:22 PM
Thiel's Avatar
Thanks guys for the encouragement, but I am not setup for the big stuff.
The Lincoln welder has a Wisconsin TF attached, still turns and the magneto trips, the marquette welder has the power cable but not welding accessories, the Hobart welder has a Wisconsin AHHD, but seems stuck.
The American Marc looks fairly complete (but what do I know), has a massive generator attached to it, possible army issued, produces 6.5kw/60cyles
and also 400 cycles. Still have 2 more V4 Wisconsins. I have to sort through many boxes, but will certainly post some of the big iron soon.
But that's how it goes, I was in for the smaller engines, but the package deal required the removal of all.
Name:	Marc front.jpg
Old 11-21-2012, 07:33:23 PM
plym49 plym49 is offline
There are still a lot of people in the Northeast that have been without power for over three weeks now. Too bad there is no good way to get those units to them instead of the scrapper. Sounds like a good opportunity for the Red Cross to arrange a mercy trip. Get those hulks delivered to a couple of repair shops in the affected areas to get them running out out to some folks.
Two Cylinder Wisconsins AugerCreek Wisconsin Engines 4 11-08-2012 05:33:17 PM
Continental 162-163 engines. lincoln- miller welders Straight Arrow Welding Shop 7 02-03-2012 12:01:59 AM
Loads & Loads of Engines Doug Waggonner Oil Field Engines & Related Equipment 26 12-14-2011 10:13:46 PM
Novo hit and miss engines by the trailer loads *video* Tom Sampson YouTube Old Iron Videos 0 09-18-2011 09:41:10 PM
Salvage Yard for Lincoln Welders Holland501 Welding Shop 2 01-04-2011 06:10:17 PM
