John Deere LUC starter
this thread has 3 replies and has been viewed 2277 times
Old 01-04-2013, 10:57:18 PM
RLindley RLindley is offline
Default John Deere LUC starter
How much of a problem would it be to adapt a John Deere M starter to an Luc power unit? They seem to be easier to find than the LUC starters. Thanks in advance, Ron
Old 01-10-2013, 05:53:28 PM
mmcdonald mmcdonald is offline
Default Re: John Deere LUC starter
They look very similar and in fact most parts are identical. I think something about the drive end casting is the reason they aren't directly interchangable but don't have both to compare at the moment. Good luck.
info@mcdonaldcarb.com
Old 01-10-2013, 09:53:35 PM
Thanks for the reply. Seems to me that i read somewhere that you have drill a new dimple for the set screw that holds it in. ron
Old 01-12-2013, 09:58:39 PM
DBFarms DBFarms is offline
If you want to put a starter on an LUC you may need to get a different flywheel. I went through an LUC completely and the flywheel did not have the starter gear teeth on it so I was not able to put in a starter. If I remember right you will have to drill a hole for the set screw because the cast does not have holes for a starter, just the end cap. Hope this helps.
Help With John Deere 317 Starter... KenS999 Garden Tractors and Mowers 12 11-01-2011 09:44:47 AM
John Deere LA Starter Issue Lvolling Antique Farm Tractors 1 08-11-2011 01:22:26 AM
John Deere 620 Starter Problem patrickingalls Antique Farm Tractors 3 02-19-2011 04:14:03 PM
John Deere B Starter parts trashman6062 Antique Farm Tractors 9 10-08-2010 05:23:14 PM
John Deere Model A starter Clarence McGehee Antique Farm Tractors 2 05-27-2008 08:54:40 PM
