mccord oiler
this thread has 5 replies and has been viewed 701 times
Old 04-10-2019, 03:56:14 PM
David A. David A. is offline
Default mccord oiler
I am rebuilding a McCord 8 position oiler that came off a twin cyl Bessemer, any one have parts pictures or specs or any extra parts?
Old 04-10-2019, 08:28:41 PM
con-rad con-rad is offline
Default Re: mccord oiler
what exactly are you looking for?
Old 04-12-2019, 06:12:57 PM
the steel caps that go on the sight glass(2), a picture of inside parts would be nice, so far able to salvage all parts except check balls, can get them here
Old 05-01-2019, 06:10:34 PM
Attached is a cross sectional view of a McCord. Hope it helps!
The steel caps should be easy to make, and balls of all sizes can be found on McMaster.
connor
Name:	McCord Oiler.jpg
Old 05-01-2019, 06:11:58 PM
I also repaired this McCord for one of my engines. It's a different style than the photo i showed. Maybe this can help too.
https://www.youtube.com/watch?v=oDDeEw1Wn8c&t=1s
Old 05-02-2019, 04:37:02 PM
thank you con-rad, video very helpful, I got mine working correctly, these getting hard to find, ill probably put it on shelf, might need it , thanks
McCord force feed oiler disassembly and repair con-rad Oilers, Lubricators and Grease Cups 1 11-16-2018 06:12:11 PM
McCord Force Feed Oiler Cleanup Early Iron Oilers, Lubricators and Grease Cups 2 03-19-2017 06:47:00 AM
McCord oiler? Temple2426 Steam Stationary Engines, Traction Engines 4 08-08-2009 08:50:25 PM
Does anyone know anything about a McCord oiler? Temple2426 Vintage Diesel and Oil Stationary Engines 2 07-30-2009 03:35:17 PM
McCord Lubricator Tom weatherford Antique Engine Archives 1 05-01-2004 02:21:58 PM
