Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
wire source for a wire tie bailer
this thread has 3 replies and has been viewed 1271 times
Old 06-10-2014, 11:17:48 AM
Kelly Barnett's Avatar
Kelly Barnett Kelly Barnett is offline
Default wire source for a wire tie bailer
I had a lady contact me asking where to source wire spool for a wire tie bailer. This would be like a Oliver 60-W bailer. I know guys pick up small amounts of wire for hand tie bailers but I'm not up on automatic wire tie bailer supplies. I'm at a loss for any information to forward on to her. Any thoughts? Thanks
Kelly
Old 06-10-2014, 11:26:35 AM
Mike Rock Mike Rock is offline
Default Re: wire source for a wire tie bailer
Your local scrap dealer or whomever recycles cardboard usually uses a baling machine that uses wire. It works well on hay balers as well, at least the ones you sit down and hand feed wires through.
Old 06-10-2014, 11:39:05 AM
Any good farm store should have baling wire. Tractor supply, local co-op, etc. There are still a few folks using wire balers nowadays.
Old 06-10-2014, 02:17:24 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Many can special order it as they likely don't keep it on hand. Also I think that only the larger rolls can be had, the smaller rolls that my JD 116 uses are not available. Then you have to rig up a bigger wire box on the baler. It isn't cheap! F.J.W.
3 Wire to 2 wire control for Transfer switch MBB Onan Generators 10 10-01-2010 08:58:40 AM
Source for wire hose clamps DavidRaines Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 11-24-2009 04:13:29 PM
Need a source for custom wire rope (cable) MowerFan Small Air Cooled Gasoline Engines 1 07-10-2007 09:28:53 PM
Need source for old-pattern ignition wire tirediron Antique Farm Tractors 3 03-08-2007 10:00:05 PM
Wire terminal source needed Mike Monnier Hit & Miss Gas Engine Discussion 2 05-29-2005 10:47:53 AM
