Oil Field Engines
Bessemer project
this thread has 4 replies and has been viewed 2252 times
Old 08-18-2014, 12:20:39 PM
GMWoodchuck GMWoodchuck is offline
Default Bessemer project
ID:	203272I am posting this looking for a little insight. I recently finished a small project for a local club on their 40 hp. Bessemer. The exuast valve on the engine would stick open after a short time running, so I disassembled the valve block and inspected all components cleaned and reassembled. I found that they weren't running an oil cup at the exuast valve cup and as the engine heated up parts expanded and stuck. it was a fun project that I enjoyed. Now I am looking for A little information on this engine since not much is known about it. Any pictures I can find online that are similar are of Cooper Bessemer 4 stroke engines but this engine is only cast with the name Bessemer in the crankcase. Any Ideas on year or ID tag location would be greatly appreciated.
Old 08-18-2014, 07:58:22 PM
con-rad con-rad is offline
Default Re: Bessemer project
i can't give you any insight, but what club in CT are you in? i thought i've been to every show in this state but i don't recognize this engine.
The Following User Says Thank You to con-rad For This Post:
Old 08-18-2014, 11:55:49 PM
CStaples CStaples is offline
The sister to that engine can almost be seen from rt 5. It has a tag on it located under the mechanical oiler. There was also one for sale on this site within the last year.
Old 08-18-2014, 11:59:31 PM
This engine in on display at the Conn. River Antique Collectors Klub or CRACK in Ely VT. They will be running this engine at there show on 8/23/14
Old 08-21-2014, 11:02:16 PM
I have removed 3 of these engines in recent years from the Bradford Pa. oil fields. The design was introduced in 1926 (I think) and the Cooper merge was in 1932 (again going from memory) so your club's engine would be from that period. They were made as a pumping engine like yours or a tandem unit with compressor. Send me an e mail & I will forward some of the literature I have on them. Bill Klein
Future Project 80hp Bessemer Randy L Peterson Vintage Diesel and Oil Stationary Engines 1 09-17-2012 08:37:20 AM
Newest Project (Bessemer) JKWidener Hit & Miss Gas Engine Discussion 35 10-15-2009 08:46:11 PM
5hp BESSEMER HVFD FireFighter Oil Field Engines & Related Equipment 22 10-05-2009 10:32:46 PM
Bessemer 20 or 25 HP holmesjsh Oil Field Engines & Related Equipment 3 12-02-2007 08:01:37 PM
25 hp bessemer JunkmanIH660 Hit & Miss Gas Engine Discussion 4 09-29-2007 07:39:29 PM
