Grandfathers WX11.
this thread has 7 replies and has been viewed 2869 times
Old 11-02-2014, 02:03:43 PM
skankingiant skankingiant is offline
Default Grandfathers WX11.
Well I thought it was about time I cracked on restoring Percy's old WX11, it has been sat in his garage under my care looking sorry for 4 years or so, We lost my grandfather in August 2010 to spreading cancer.
We swapped it already restored for a Ruston 6PB with Villiers magneto, that was 1994, and we never put spanners on it.
Villiers WX11 by skankin_giant, on Flickr
1st oddity is there was no C clips retaining the gudgeon pin, it just had 2 pads in either end but it was free to float! The small end is also a bit suspect, luckily I have a good spare, this was one of the jobs the previous owner had done.
The Following 2 Users Say Thank You to skankingiant For This Post:
Old 11-02-2014, 02:05:51 PM
Default Re: Grandfathers WX11.
They come apart easy enough.
The Following User Says Thank You to skankingiant For This Post:
Old 11-02-2014, 02:10:51 PM
Could have probably done with a de-coke at some time in its life, it is hanging!
The expansion chamber is 1" thick with it!
Looks like it was green originally.
New handle fits a treat
---------- Post added at 06:10 PM ---------- Previous post was at 06:08 PM ----------
And finally the crank is out.
This is where the main work is to be done, new big end is required, plus one of the main bearings are suspect.
Thats it for the moment, will be done as and when, as it's done in memory to Percy, I don't know if to keep it burgundy or put it closer to the original green.
Cheers, Steve
The Following 6 Users Say Thank You to skankingiant For This Post:
Old 11-03-2014, 10:14:32 AM
Started to clean the exhausts out, had quite a blaze going!
DSCF3218 by skankin_giant, on Flickr
But I was worried someone might call the fire brigade!
DSCF3219 by skankin_giant, on Flickr
DSCF3222 by skankin_giant, on Flickr
DSCF3220 by skankin_giant, on Flickr
Flames have died down now, just got to leave it to cool before shaking it out!
Cheers, Steve
Old 11-14-2014, 10:39:12 AM
While I decided what to do with the big end (mainly where to send it!) I started the clean and strip the paint.
The Exhaust base went up quite well once I introduced a new blow lamp...
DSCF3417 by skankin_giant, on Flickr
I then got some of my old faithful carb cleaner and turned to the crank case halves, it sure does a good job of cutting though the old 2 stroke crap!
DSCF3418 by skankin_giant, on Flickr
DSCF3419 by skankin_giant, on Flickr
They paint seems to be coming off OK, it is a bit stuck in places.
DSCF3420 by skankin_giant, on Flickr
The block and flywheel have a bit of original paint left. So I might try and scrape the red off slowly and see what we are left with.
DSCF3421 by skankin_giant, on Flickr
DSCF3423 by skankin_giant, on Flickr
Cheers, Steve
Old 11-15-2014, 12:24:29 PM
While I had 5 mins I fitted the replacement small end, nice a tight again now
S0013425 by skankin_giant, on Flickr
S0033427 by skankin_giant, on Flickr
S0023426 by skankin_giant, on Flickr
Cheers, Steve
The Following 3 Users Say Thank You to skankingiant For This Post:
Old 05-10-2015, 05:18:52 PM
Managed to get some paint onto the WX11, getting there slowly!
DSCF5248 by stephen williams, on Flickr
DSCF5250 by stephen williams, on Flickr
DSCF5251 by stephen williams, on Flickr
Bit of overspray on the hooper :embarrassed:
DSCF5252 by stephen williams, on Flickr
Cheers, Steve
The Following 5 Users Say Thank You to skankingiant For This Post:
Old 06-28-2015, 11:47:51 AM
Getting their slowly.
DSCF5476 by stephen williams, on Flickr
Just waiting on the crank to come back now...
Cheers, Steve
Villiers WX11 Replacement Piston Harddisk25 Small Air Cooled Gasoline Engines 0 01-19-2013 07:08:25 PM
Undoing Bolts on a WX11 Harddisk25 Small Air Cooled Gasoline Engines 1 01-13-2013 09:30:38 AM
Grandfathers old Ottawa georgiaboy1021 Hit & Miss Gas Engine Discussion 0 09-14-2008 04:21:52 PM
tests and grandfathers Allen Steam Stationary Engines, Traction Engines 13 07-06-2003 12:13:20 PM
