IHC clutch handwheel G-893
this thread has 8 replies and has been viewed 1019 times
Old 02-15-2015, 08:47:27 PM
FarmSC's Avatar
FarmSC FarmSC is offline
Default IHC clutch handwheel G-893
I have a 6hp M with a clutch that has this handwheel (G893) on it. It is obviously not the correct one as the hole in the wheel is much larger that the shaft. Anyone know which clutch this goes on? And what is the part number for the one I need? And while I'm at it, I'd gladly trade it to someone that needs it for one that fits mine. I don't want to sell it, as it will work on mine in a pinch, but I will trade it.
Thanks,
Kevin
Kevin Harbin
Seneca, SC
www.snowcreekmills.com
Old 02-15-2015, 09:40:33 PM
Default Re: IHC clutch handwheel G-893
Kevin: The hand wheel G-893 is used on the IHC Famous line of engines, 4-25hp. I couldn't find a specific hand wheel for the 6HP-M , but found hand wheel 940T for the 1 1/2 & 3HP M's. It could be the same .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
The Following User Says Thank You to Paul Spence For This Post:
Old 02-15-2015, 09:50:33 PM
FarmSC's Avatar
Thanks Paul,
ok, just went and looked at it some more...another part on the clutch appears to be
G-6113. Does your book show if this handwheel fits with this part number? Also, I don't know what this clutch SHOULD be on, but it bolts up to my 6 M. It's different than the one on my other 6M, as it has the wheel with the covered hub.
Kevin
Kevin Harbin
Seneca, SC
Old 02-15-2015, 10:16:46 PM
clappo clappo is offline
I Have two 6hp clutch assemblys both handles are stamped G893 both are the early type without the cover one handle is very loose on the shaft suspect it is just worn will bush it when I restore the engine .cheers clappo
The Following User Says Thank You to clappo For This Post:
Old 02-15-2015, 10:20:36 PM
FarmSC's Avatar
Maybe I was *gulp* WRONG! and it was just that loose. I am anxious to see if it matches up part number wise with the other part number I posted.
Thanks,
Kevin
Kevin Harbin
Seneca, SC
Old 02-15-2015, 10:33:36 PM
Bryan Storey Bryan Storey is offline
Thats the correct handwheel. Its not uncommon for the hole to be wore out and most of the time egg shaped. I have had to bore a few of them out and put bushings in them.
The Following User Says Thank You to Bryan Storey For This Post:
Old 02-15-2015, 10:41:34 PM
FarmSC's Avatar
Ok, what kind of clearance am I looking for? I don't think I want it too tight or stopping it from spinning to disengage may be difficult. What say ye?
Thanks for all the replies so far!!
Kevin
PS...to the people up north...Please call your cold, snowy, icy weather back before it gets here Monday afternoon. I know that y'all accidentally let it out and would really appreciate your recapturing it before it makes a mess down here. Wife just saw a tongue-in-cheek post on Facebook where someone had a partial loaf of bread and most of a gallon of milk for sale for $1000.00. We aren't designed for that kind of stuff down here!
Kevin Harbin
Seneca, SC
Old 02-16-2015, 09:21:39 AM
Kevin: Part # G-6113 shows as a hand wheel shaft guide for the 4 & 6hp Famous engines. The hand wheel bore on most of the Famous type engines is usually found to be "LOOSE", just from ware, spinning on the shaft.
Old 02-16-2015, 09:45:11 AM
A balmy -11 f this morning here on the coast of Maine with a 40 knot breeze behind it.
this weekends blizzard missed us by a few miles. We got 6-8 inches and towns less than 20 miles away got 18-24 inches of the lovely white stuff.
I've still got 3 foot drifts from the wind to go out and plow.
Rhodes 7" metal shaper needs a Step pulley/handwheel George Kulisiewicz Machine Shop and Tool Talk 11 01-25-2015 03:16:36 PM
What does this little clutch fit? Chris Epping Hit & Miss Gas Engine Discussion 1 11-04-2012 10:41:28 PM
Peerless "Handwheel" reverse Jim Mead Steam Stationary Engines, Traction Engines 5 11-20-2010 10:42:29 PM
Clutch on 15/30 Ihorse Antique Farm Tractors 6 11-12-2008 07:43:06 PM
8N 3 pt goes down when clutch is in sawyersmill Antique Farm Tractors 7 06-16-2007 12:45:38 AM
