US Carburetion snorkel kit REVIEW!
this thread has 21 replies and has been viewed 7219 times
Old 04-09-2016, 06:12:30 PM
bobbyz72 bobbyz72 is offline
Default US Carburetion snorkel kit REVIEW!
It SUCKS! Installed on a honda 6.5 hp, 3600 rpm, 3kw generator. Hit the primer button, pull rope, generator fires on first stroke and thats it. Adjust gas valve repeat over and over till out of adjustment. Repeat 2 more times. Will only run "poorly" if primer button full pressed, release and she shuts down. Put choke on about 75%, hold primer button, runs good.
Start generator on regular fuel, and start opening gas block adding natural gas to the engine. At some point the engine should start running pooly or stall due to over rich mixture. How ever, at no point, did engine get out of tune.
I believe the snorkel is undersized, not allowing enought fuel to do anything.
Old 04-09-2016, 06:33:10 PM
BRae's Avatar
BRae BRae is offline
Default Re: US Carburetion snorkel kit REVIEW!
I have tried several of those kits... VERY DISSAPOINTED! They seem to want the consumer to do their R&D work for them. The older venturi kits were okay but the snorkel kits are J-U-N-K. in my opinion.
The Following User Says Thank You to BRae For This Post:
Old 04-09-2016, 06:56:41 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
The concept is good. I got full power out of a natural gas JB with a home-made 'snorkle' type of carb mod.
Old 04-09-2016, 07:00:41 PM
I emailed them, we'll see what they say. Emailed them same thing i wrote here.
Old 04-09-2016, 07:38:58 PM
len k len k is offline
Sounds like snorkel tube may be too small dia to flow enough fuel.
I would expect the snorkels to be sold in various sizes coresponding to various sized engines (CC or hp)
Old 04-09-2016, 11:42:48 PM
Tim0477 Tim0477 is offline
Demand regulator defective or out of adjustment?
Tim
Old 04-09-2016, 11:44:41 PM
Got the load block adjustment valve opened up?
Old 04-10-2016, 03:13:31 AM
lokay5's Avatar
lokay5 lokay5 is offline
Talking Re: US Carburetion snorkel kit REVIEW!
"It SUCKS!"
You mean it doesn't work? No! I'm shocked. SHOCKED I tell you! Who'da thought ....
(sarc/off)
Old 04-10-2016, 08:05:33 AM
Billy J Shafer's Avatar
But they said it worked.
Old 04-10-2016, 09:58:15 AM
What's the length and diameter of the gas tubing between the snorkel and regulator?
Old 04-10-2016, 10:03:38 AM
cornbinder89 cornbinder89 is offline
Some (most) demand regulators have a vacuum lock. They will not open until manifold vacuum is supplied to a 1/8" port on the regulator. Could be problem #1. 2nd if the unit was too small, it would function at reduced power, not give a no run condition. If it was too large, it might not run.
I would look at the demand regulator 1st, as it seams not to be supplying the fuel, as you say it runs good with the primer pushed in (overrides the vacuum lock)
Old 04-10-2016, 11:34:46 AM
Motorhead's Avatar
To me, the "Motor Snorkel", by installing it into the inlet of the carburetor would cut down the total amount of volume the carburetor will pass through it.
I have a new complete CCK conversion kit in the classifieds.
Old 04-10-2016, 01:00:44 PM
No van lock, 1/8 ports are to be left open. #2, i have no run, due to lack of fuel.
---------- Post added at 11:00:44 AM ---------- Previous post was at 10:56:35 AM ----------
Tim
Will give that a try this afternoon, im pretty sure i have a spare.
Old 04-10-2016, 01:03:22 PM
try supplying vacuum to the 1/8 port, it is possible they supplied you with a demand reg that still has the vacuum lock (you can use a hand vacuum pump for this test). No fuel does not indicate too small a mixer, it indicates no signal to the demand reg or some other reason for the demand reg to not supply fuel.
Old 04-10-2016, 07:23:10 PM
If the OP has a Garretson KN regulator, DO NOT apply 'vacuum' to that port. The KN does not have a vacuum lock-off.
Again, what diameter and length tubing did you use?
The Following 2 Users Say Thank You to Jim McIntyre For This Post:
Old 04-10-2016, 07:54:18 PM
THEY, supplyed, 1/4" tubing, i cut it to maybe 8 inches long. the snorkel is too small, i knew it when i opened the box.
Old 04-10-2016, 08:02:32 PM
1/4" tubing? YIKES!, that's at least part of the problem...
FYI - here's the 'snorkel' I made for a JB. I used 3/8" copper tubing.
The Following 3 Users Say Thank You to Jim McIntyre For This Post:
Old 04-10-2016, 09:00:57 PM
Motorhead's Avatar
Nice work Jim!...
Old 04-10-2016, 09:14:55 PM
John C John C is offline
I installed a Snorkel kit on my 1982 Lincoln Weldpower 150 with a Kohler 10 HP rope start engine. I hooked up everything but the Snorkel, on a temporary basis for testing purposes. I would not run-period. Since I had spare LP gas parts on hand, I stared at the LP gas tank and replaced one component at a time (LP tank, high pressure regulator, hose from high pressure regulator, demand regulator). When I got to the hose from the demand regulator to the Snorkel, I found that I could blow through the hose in one direction, but in the other it was almost plugged. I found that there was some “Flashing” from the hose molding process that was acting as a check valve. At this point the gas pressure is so low it could not get through. Normally it is a dirt dobber that has plugged the hose. (A dirt dobber can ruin reloading trays in just a few days).
After cleaning out the hose, the welder ran fine with some minor adjustment to the regulator output load block. Since the demand regulator does not have an idle circuit, the engine has to be brought to full speed on starting.
I am in the process of converting some of my other generators to propane. I have test run a Winco/Briggs 5KW on propane with a homemade connection after the air filter with good luck.
Old 04-12-2016, 04:05:47 PM
Photos of my Lincoln Welder with Snorkel LP gas conversion.
ID:	251372   Click image for larger version
ID:	251373   Click image for larger version
ID:	251374   Click image for larger version
The Following User Says Thank You to John C For This Post:
Priming in hilly areas - Steam dome snorkel pipe vicolive Steam Stationary Engines, Traction Engines 17 04-09-2016 12:28:04 AM
Motor Snorkel rthacker77 Generac Generators (SEARS, etc.) 3 02-26-2015 10:14:59 AM
1908 Gas Review Sta-Rite Ads. Denis Rouleau Hit & Miss Gas Engine Discussion 0 12-05-2008 04:51:46 PM
Review: Drill Doctor Paul Gray Antique Engine Archives 9 03-03-2002 10:57:17 PM
