Continental AA7
this thread has 12 replies and has been viewed 2068 times
Old 08-04-2016, 03:10:23 PM
bsaeland bsaeland is offline
Default Continental AA7
Can anyone tell me where to find information on a Continental model AA7, Spec 2, Serial Number 7893. Looking for rebuild information as well as the year it was made.
Thank you in advance.
Brian
Old 08-04-2016, 08:38:31 PM
G.M.Johnson G.M.Johnson is offline
Default Re: Continental AA7
Heres a few places that might help out. I also have a later April 1958 revision, factory copy of the mechanics manual that I could probably scan if needed. The AA series engines came out sometime in 1947 and true production started in 1948 so I would date your engine, being a low serial number, sometime around there. If you have the block casting number you could narrow it down maybe a little better.
http://gardentractortalk.com/forums/...ental-engines/
http://www.michiganssmallengineresou...ntinental.html
Old 08-05-2016, 09:25:31 AM
Dick DeBuse Dick DeBuse is offline
Spec No 2 was supplied to Moto Mower for one of their mowers. It had a Scintilla magneto, 2 quart tank, mechanical governor, oil bath air cleaner, 42" throttle control, Tillotson carburetor. With such a low type number, it was most likely made in 1946-47. A Operation and parts manual for the AA7 is readily available on ebay. A Mechanics Manual is usually available also on ebay and will have any rebuild info needed. Scintilla magneto parts may the hardest to locate. Probably used on a reel mower, possibly with magneto powered lighting.
Old 08-06-2016, 10:46:37 PM
Chris M Chris M is offline
I am just finishing up the rebuild on my AA7, parts are not that easy to find but are out there. I have a pdf of the repair manual I can send you if you want it. Also know of a couple places to find some parts.
Old 09-26-2016, 09:45:00 PM
Please send me a copy of the repair manual if you don't mind. Thank you very much.
Old 10-31-2016, 11:57:02 PM
Sorry haven't been on for awhile. I need your email address to send pdf
Old 11-01-2016, 06:38:21 AM
IWL BCNU IWL BCNU is offline
I have an AU8, would this manual show how to set timing when installing the cam shaft and torque specs?
Old 11-01-2016, 04:41:20 PM
It might it does cover a few models
---------- Post added at 04:41:20 PM ---------- Previous post was at 04:37:45 PM ----------
There should be a dot on the cam and the crank to help you line them up correctly.
Old 11-01-2016, 09:42:52 PM
Here is link for a couple downloadable continental manuals.
The Following User Says Thank You to Chris M For This Post:
Old 11-15-2016, 02:21:49 PM
HI Chris - My e-mail address is Bsaeland@hotmail.com
Thanks for your help.
Brian Saeland
Old 11-28-2016, 01:20:52 PM
MallaryJ MallaryJ is offline
I need a fuel tank for an AA7 that mounts on the shroud side. This is a top carb model. Also, I have a maintenance book with all specs. If you send me questions i can answer them.
Old 02-17-2017, 11:35:53 PM
Kevjen1 Kevjen1 is offline
Did you locate a magneto and capacitor by chance? If so could you send me information on where to find one. I have a 1947 AA7 series 1 that I am rebuilding and need to find one. Thanks gilbertsonk76@hotmail.com
Old 02-18-2017, 11:04:05 AM
Parts needed will depend on which magneto is used on your engine You should be able to read the mfgr on the flywheel.
The Following User Says Thank You to Dick DeBuse For This Post:
Continental 6B Keithde1 Hit & Miss Gas Engine Discussion 3 10-22-2014 01:00:40 AM
Continental AA7 Sean B. Small Air Cooled Gasoline Engines 8 01-27-2014 06:39:42 PM
Continental AA7 elroy6468 Small Air Cooled Gasoline Engines 2 06-30-2010 09:30:23 PM
Continental AC6 Jim Cobb Garden Tractors and Mowers 1 12-11-2008 10:13:01 PM
Continental F-163 Paul J. Morrison Generators & Electric Motors General Discussion 2 01-23-2005 03:28:21 PM
