Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Olds 1904, 2hp, No.2, Type "A" Engine/Waterpump
this thread has 0 replies and has been viewed 1210 times
Old 08-25-2016, 12:26:20 PM
John Davis's Avatar
John Davis John Davis is offline
Arrow Olds 1904, 2hp, No.2, Type "A" Engine/Waterpump
Manufactured by Olds Gas Power Company of Lansing Michigan in 1904. This is a 2 horse power engine Style no. 2, type "A" with a 4" bore and a 6" stroke, Self contained and designed to run at 450 rpm. It was used to irrigate a grapefruit grove in South Florida for many years. The water pump is a five inch diameter double action pump with brass sleeved cylinder. It also has a power take-off pully to do belt work if so desired. This engine was in bad shape when found but my father (Heller Davis) did an excellent job restoring the engine/water pump to it's present state.
The Following 6 Users Say Thank You to John Davis For This Post:
Olds-Seager Type "A", 1-1/2hp. ??? Denis Rouleau Hit & Miss Gas Engine Discussion 15 08-24-2015 05:26:14 PM
1904 "Waterman" 2 cyl-2-stroke inboard Tom Schaech Antique Marine Engines and Outboard Motors 21 06-16-2012 08:58:43 AM
Early Briggs Stratton "Y" with "X" in type number mschreiber Small Air Cooled Gasoline Engines 7 05-14-2012 09:33:34 PM
"Olds" engine information needed. Dave Beck Hit & Miss Gas Engine Discussion 7 01-26-2009 08:35:26 PM
Rex Messners' : Type A "Olds" Engine dusty Antique Engine Archives 2 09-29-2004 02:53:42 PM
