Royal Vacuum Motors: Add a Ground Wire to Existing Two-Wire Field
this thread has 4 replies and has been viewed 885 times
Old 11-01-2016, 11:35:36 PM
ClassicTVMan1981 ClassicTVMan1981 is offline
Default Royal Vacuum Motors: Add a Ground Wire to Existing Two-Wire Field
For all those of you on here that own a Royal metal upright or metal hand vacuum (before 1995), how many of you have tried to add a ground lead to convert the existing field to three-wire operation?
This may be somewhat easy to do, as the fields used on both their household and commercial machines are the same.
I am asking you all about this because, it is also true that until 1973, all Royal commercial-duty metal uprights also had two-wire cords. For conversion, besides a new 50-foot 3-wire cord, you'd also need to purchase the following parts:
1-031101-000 Ground Lead
3-311323-600 Short Cord & Lug Assembly, 3 Wire
1-880707-000 Screw, Ground Lead
1-006318-000 Lockwasher, Ground Lead Screw
Attached Picture: 501 and 3-501 Parts Drawing, 4/25/1984
~Ben
Old 11-02-2016, 09:58:02 AM
Default Re: Royal Vacuum Motors: Add a Ground Wire to Existing Two-Wire Field
Interesting. I have the metal hand vac and am wondering why and what are the benefits of doing this mod.
Old 11-02-2016, 11:51:03 AM
Well, for the pre-1973 equipment that I mentioned, it will finally meet current OSHA standards requiring three-wire cords.
~Ben
Old 11-02-2016, 03:18:49 PM
Aww hell, OSHA is just a small town in Wisconsin. Nowait,, I'm in Wisconsin so maybe I'll just drive there.
thx
Old 11-02-2016, 11:06:18 PM
You wouldn't ground the field, just the body of the vacuum.
Onan 2 wire to 3 wire stator conversion? HonestJohn Garden Tractors and Mowers 0 11-08-2014 07:14:47 AM
Onan 3 wire to 2 wire switch MBB Onan Generators 6 10-20-2012 08:11:18 AM
3 Wire to 2 wire control for Transfer switch MBB Onan Generators 10 10-01-2010 08:58:40 AM
Is this a ground wire or a condenser wire? edpdx Magnetos, Ignition Coils and Spark Plugs 1 06-15-2010 08:38:54 AM
Ground wire question beeman Generators & Electric Motors General Discussion 13 02-20-2007 12:02:02 AM
