Green horn needs help,,,
this thread has 1 replies and has been viewed 2005 times
Old 09-05-1999, 11:49:36 PM
Mike Wurth
Default Green horn needs help,,,
I just obtained a single cly "hit and miss" powered bucking saw from a yard ##### and am dying to get it running. From reading some of the articles in this site I understand it is not wise to just "fire it up" and see how she runs without first going thru the engine to check all parts for wear. I agree with this and this is my first hurdle to jump. With no identifing numbers or brand name I don't know where to look for the proper manuals and how to ask questions or get advice on how to go about this rebuild. It looks like everything is there with the exception of the magneto. Everything turns freely and I feel good comppresion while turning the engine over by hand. I guess what I'm asking is WHERE DO I START??? Thankyou in advance. Mike Wurth
kkk
Old 09-11-1999, 08:48:24 AM
Bob
Default Re: Green horn needs help,,,
First check for cracks anywere on the engine. Check to make sure that all spinning components are tight( rod bolts main bearing caps etc. ) Then you will need an ignition source. Then try to fire it up making sure all parts are free moving. use a small amount of gas in this prosess. Please, No eather!! Once the engine hits a few times and your shure the govener is working, Let it go! Plase make shure you lubricate everything real well. Good luck!!
Air Horn MCanady Railroads and Equipment 6 07-20-2019 05:12:28 PM
LESLIE Supertyfon Train Horn (Whistle) S-2M-R (Horn #’s 31 & 44) Found Paul Spence Railroadiana 4 04-11-2018 03:07:06 PM
John Deere classic green vs ag green SlantdashA Antique Farm Tractors 5 07-30-2012 01:36:00 PM
Oil field Green Horn John Davis Oil Field Engines & Related Equipment 23 04-04-2010 10:55:15 AM
Horn Motor Will Antique Autos and Trucks 6 10-08-2006 09:08:02 AM
