Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Mccormick Deering " M" Lifting with Harbor Freight hoist
this thread has 1 replies and has been viewed 1221 times
Old 06-13-2017, 12:08:10 PM
Jimjakosh Jimjakosh is offline
Smile Mccormick Deering " M" Lifting with Harbor Freight hoist
Here is a video I shot today showing how I handle my McCormick Deering "M" engine when I have to work on it off the truck.
I used a tow strap to make my lifting harnesses and hook them to my Harbor Freight 1300# lift that is on a trolley in my barn.
https://youtu.be/tH-MP0Tce3E
The Following User Says Thank You to Jimjakosh For This Post:
Old 06-13-2017, 06:35:15 PM
Tom G Tom G is offline
Default Re: Mccormick Deering " M" Lifting with Harbor Freight hoist
That is a Very Improper way to lift an engine! NEVER lift an engine by attaching straps to the top of the flywheels. As the engine is lifted, pressure will tend to pull the tops of the flywheels inward. You can very easily bend your crankshaft this way. Think about it!
The correct way is to run a piece of pipe between the flywheel spokes and attach your lifting strap to the pipe between the engine block and the pipe, on each side. The piece of pipe applies pressure evenly to the flywheels, with only an upward pressure on them.
It would be a shame to bend the crank on that nice engine!
The Following User Says Thank You to Tom G For This Post:
McCormick-Deering "M" casting kit caseyvand Scale Model Engineering 1 02-11-2014 09:45:39 AM
McCormick Deering lady? "art print" JKWidener Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 03-19-2010 10:38:48 AM
My "M" is Racing (1 1/2 McCormick Deering Engine) djamatoit Hit & Miss Gas Engine Discussion 19 01-05-2009 12:05:35 AM
McCormick - Deering "M" Flywheel clearance David Hughes Hit & Miss Gas Engine Discussion 11 03-03-2008 04:54:58 PM
McCormick Deering "M" Bosch?? Shane Ball Antique Engine Archives 2 02-04-2001 06:39:27 PM
