MOPAR Powered 30SK Set
this thread has 77 replies and has been viewed 3489 times
Old 08-06-2017, 07:30:56 PM
Default MOPAR Powered 30SK Set
Well, it was mentioned to start a MOPAR thread and recommended it be based on the MOPAR slant 6 engine as is what poweres the SK.
This thread has more pictures of the process of getting it hooked up:
https://www.smokstak.com/forum/showt...=162757&page=3
I was wondering if I could mount the intake in the pictures to the slant 6 to give it more KW output or, quicker responce??
This is my MOPAR thread!
Name:	2Dart Pictuires and SKengine 007.jpg
ID:	288094   Click image for larger version
Name:	2Dart Pictuires and SKengine 008.jpg
ID:	288095   Click image for larger version
Name:	2Dart Pictuires and SKengine 012.jpg
ID:	288096   Click image for larger version
Name:	2Dart Pictuires and SKengine 013.jpg
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
Old 08-06-2017, 07:32:28 PM
Default Re: MOPAR Powered 30SK set
Some work, the long long process of maybe getting it running.
Name:	2Dart Pictuires and SKengine 009.jpg
ID:	288098   Click image for larger version
Name:	2Dart Pictuires and SKengine 010.jpg
Old 08-06-2017, 07:43:34 PM
Troll's Avatar
Troll Troll is offline
Still have my 68 Formula S fastback Barracuda car. Original 340 4 speed with 8-3/4 "Sure Grip". Had it since April 26, 1976 when original owner gave it to me the day I received my driver's license.
The Following User Says Thank You to Troll For This Post:
Old 08-06-2017, 07:51:28 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Don't see how one could use a V-8 intake manifold on an inline 6.
Many years ago I had a '74 AMC Hornet with a 232 cu. in. I-6. Changed out the crank & rods and turned it into their optional 258 cu. in. motor. Found an aluminum manifold from "Clifford 6=8" that would take a 4 BBL carb, but used a block-off plate and a big 2 BBL carb.
They offer a manifold for your slant six, but they ain't cheap....
http://www.shop.cliffordperformance....-45-4500WH.htm
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 08-06-2017, 07:58:35 PM
I have owned a bunch of Chrysler products from '56 to '15. Still have a few.
Some day I will find a 71 Plymouth GTX/RR/Satellite I can afford. Best looking car they ever made.
Put an Offy 4 barrel intake and a 390 Holley on the SK.
Old 08-06-2017, 08:23:38 PM
I have owned the numbers matching pictured 1969 Dart Swinger 340 4-speed since 1980. I don't know how many previous owners. I also have another 69 340 Swinger that I have had since about 1976. In high school I also had a 69 340 Swinger, it succumbed to cancer from living in Ohio.
Old 08-06-2017, 08:32:54 PM
PnishrPW PnishrPW is offline
I've got a complete original Hyper Pak I've thought about using on my SK, I'll never use it on a vehicle. Also hanging onto an aluminum block out of a Feather Duster, can't remember where it even came from... In reality if I were to swap I'd probably go with a Super 6 2bbl set-up.
Ya wanna make AMC 6 cylinder power? 258 rods/crank in a HO 4.0 liter configuration. 86-90 258 4 weight crank, 2000-1 intake/exh, NON HO cam (87-90), HO block/head will net about 230 hp, a ton of torque and AWESOME driveability from idle to redline. Got a mint '84 Eagle SX-4 (AMC Spirit) to drop the above combo in plus a '94 Cherokee AW-4 4sp auto/NP242 t-case and stock computer/harness to round the package. I've built quite a few 4.5L strokers, always a hit. 3.10 first gear in the AW-4 helps too!
---------- Post added at 05:32:54 PM ---------- Previous post was at 05:27:40 PM ----------
Agreed, I also own a '71 Sebring Plus, 451/auto Tic Toc tach and slapstick + more. Had it since '89, hands down my fave car. Was looking for a GTX, settled for this and couldn't be happier!
Old 08-06-2017, 08:47:18 PM
Troll's Avatar
Can't count the number of Mopar cars I've had, bought, and sold through the years. Always liked the A bodies and 340 engine. The "X" heads and later "J" heads are getting a bit scarce these days which is why those engines ran so well. Had several 413's, 440's, built more than a few 451's, and a single 426 "Max Wedge" in a Dodge "660" which was very fast for the time.
My car is always been a midwest car so is a bit rusty but I quit driving it at 340,340 miles to pull it down for rebuild. Never apart prior except for water pumps, timing chain, fuel pump, etc. Always kept the oil changed at 5K intervals and run the piss out of it when younger. The cam bearings were down to the copper as the babbit lining was worn away, seven of eight pistons had broken rings, and the thrust surface on the forged crankshaft was worn severely. The crank would walk almost 1/4" fore an aft in the block when pried with a bar.
I found a pair of NOS fenders at a Mopar Nationals show in 1996, a very clean set of door shells at another show in 1998, a complete reproduction interior kit from "Legendary Interiors" in 1999 and a set of NOS 340 engine callout chrome hood inserts along the way. Never did purchase reproduction rubber gaskets and seals but understand Metro Molded Rubber Products now produces them for the fastback cars.
Mine was purchased new in St. Louis by the neighbor across the street when he came back from "across the pond" so I've basically known the car since new. Never have liked the "Ember Gold" color w/lower door black stripping but it's original so never changed it. Now thinking about it, I need to get the woodgrain steering wheel rebuilt. Mine has the barracuda fish in the center cap.
Old 08-06-2017, 08:47:38 PM
My first "car" was a 1963 Dodge 1/2 ton with a 225 slant 6 under the bent up hood. I do not think it had a straight piece of sheet metal on it.
Cost: $25 & a jug of wine. Took about $150 to get it running inc. turning the crank, rings and all the other little goodies.
Those were the days.
Old 08-06-2017, 09:38:01 PM
Hey, somebody ask Don Gartlis how to do it. I'd think he'd know
Old 08-06-2017, 09:44:12 PM
I would love to tour his museum!!!!
Old 08-06-2017, 09:49:18 PM
Bryant Bryant is offline
This is my MOPAR thread![/QUOTE]
A little machine work and they might fit but would be a little over carburetored. Are they both 66 carbs and would you sell them?
Old 08-06-2017, 09:50:29 PM
Rarelyidle Rarelyidle is offline
I've definitely owned many Mopars over the last 45 years.. We currently have 3, 1992 Ram W350, 1993 Ram D350 and a 1998 Ram Quad cab (wife's hot rod). all are Cummins powered.
Here are a couple pics from over the years, gray one 1970 Cuda 440 Magnum, Black one was a real 1970 "V" code 440 6 Pak, 1971 Charger RT 440 magnum.
ID:	288101   Click image for larger version
ID:	288102   Click image for larger version
ID:	288103   Click image for larger version
The Following User Says Thank You to Rarelyidle For This Post:
Old 08-06-2017, 09:53:41 PM
MBB MBB is offline
I had a 63 Impala convertible with a 283 a power glide automatic trans. I got for $50.00 The guy I bought it from thought the motor was frozen, It was a bad starter. I had a buddy who had a 65 or 64 SS I took all his parts and put it in my 63 I converted it to a 3 speed manual. Never did get the linkage right on it. Had to be careful not to shift into reverse. I put fuely (sp) heads and a Holley high rise with 750 double pumper. I remember picking a bunch of parts at Warshawskies (sp) and driving the the car to school the next day. The muffler fell off and I had a secondary exhaust leak let off on the gas when going by a cop to hide the noise and it backfired and the cop turned around pulled me over and gave me 7 tickets.
Wish I had that car today.
The Following User Says Thank You to MBB For This Post:
Old 08-06-2017, 09:57:40 PM
What fun is a car thread without some bs thrown in.
MOPAR. Most original parts are rusted
MOPAR. My other Plymouth ain't running.
I had a 63 Polara with the olivetti transmission. Horribly designed vehicle with 10" brakes and a useless heater. I did put 100,000 miles on that $50 car though.
I do miss my 48 Power Wagon.
Old 08-06-2017, 10:13:08 PM
I can't remember of they are 1966 or 1967 carbs. In my basement I have a 1966 426 engine that I bought in 1980 that was rebuilt but never started, I pulled it apart a long time ago and it's still sitting there, since then I have acquired a 1966 Coronet (needs rear quarters amd paint) bought a new AlterKation complete front "A" frame suspension,
https://www.reillymotorsports.com/Al...Handling-Kits/
TTI headers and a DANA 60 also in the basement. Missing time and more money! $$$$$$$
Old 08-06-2017, 10:31:31 PM
Missing time and more money! $$$$$$$[/QUOTE]
Well it would look good in my brothers coronet wl21h. If you decide to get rid of it let me know.
Old 08-06-2017, 10:39:49 PM
I did have a WS23J7 67 RT HEMI, Story of another kind though. I believe the guy I sold it to had to use at least another car or two to restore it, When it was completed it was a BEAUTIFUL car though. A White Hat Special.
Old 08-06-2017, 11:09:27 PM
Jim Marcozzi Jim Marcozzi is offline
72 Duster, 360. 12.20ET
85 Shelby Charger...very custom. 2.2 Turbo @ 28 PSI. 12.36ET
ID:	288110   Click image for larger version
The Following User Says Thank You to Jim Marcozzi For This Post:
Old 08-06-2017, 11:17:14 PM
Motorhead's Avatar
darts, This might get you some extra KW! https://www.youtube.com/watch?v=7zzODTFqLTU
Those little 6's were darn good runners for their displacement.
My 1939 WILLYS Pickup.
Bought in 1971
Repair/ modification on a 30SK-18R PnishrPW Onan Generators 1 01-18-2015 06:37:48 PM
use a MOPAR electronic ignition to save the points sdowney717 Onan Generators 36 08-27-2012 02:58:25 AM
Old Gas Powered Rip saw. Erik Brinkerhoff Hit & Miss Gas Engine Discussion 0 05-13-2008 10:49:37 AM
