What is a Suitable Replacement for a John Deere M Starter and Generator
this thread has 4 replies and has been viewed 645 times
Old 07-04-2018, 01:06:42 PM
hitmissfan hitmissfan is offline
Default What is a Suitable Replacement for a John Deere M Starter and Generator
I recently started working on my John Deere M I purchased earlier this year and I'm conveting it over to 12 volt ignition system over the original 6 volt. Just a personal preference.
What I was wondering is what is a suitable starter and generator to replace the originals with? I prefer Delco products. The ones on it now would need to be rebuilt and I'm just not willing to spend the money to do it. And the rest of the system I've already upgraded.
Thanks.
Old 07-04-2018, 02:12:28 PM
Default Re: What is a Suitable Replacement for a John Deere M Starter and Generator
You don't need a 12V starter.
I've had a 12V battery on my John Deere L as long as I've had it.
I have the rest of the electrics for it but never did and never will install them.
I charge the battery once a season as it lasts forever with the magneto ignition and fast starts.
As for the generator you'll likely have better luck buying a cheap, single wire, alternator if you don't mind the modern look.
That would be the cheapest way to go.
Old 07-04-2018, 02:21:32 PM
Vanman Vanman is offline
I see 12 volt dc generators on fleabay all of the time. I'd find one that fits without too much trouble, and find a suitable mechanical regulator to go with it.
I'm in favor of original, or period correct modifications. IMHO, modern stuff has no place on vintage equipment. Otherwise where does it end? Electronic this and that? A modern fuel injected engine?? A brand new tractor? Lol. Same with cars. New stuff is for new cars.
Old 07-04-2018, 09:08:33 PM
J Ware J Ware is offline
Powermaster is a company that makes alternators that look like a generator. They are pricey, but you can have correct looks with modern technology. Check out their website, powermasters.com, just have to find one they make that will work. Jim
Old 07-04-2018, 10:37:15 PM
Ken Majeski's Avatar
I have a G Minnie with LP Heads. Hard to turn over. I don't know if it was 12 volt or not but it is now.
The best generator I had happened to be a 6 volt one so I used a Diode for a cutout and the resistor in the light switch to control the field. Charges the 12 volt battery Just Fine...
Ken Majeski, Ellsworth Wis.
John Deere LUC starter RLindley Antique Farm Tractors 3 01-12-2013 09:58:39 PM
John Deere 40 coupler shaft replacement IWL BCNU Antique Farm Tractors 1 01-17-2012 09:14:18 AM
Help With John Deere 317 Starter... KenS999 Garden Tractors and Mowers 12 11-01-2011 09:44:47 AM
John Deere LA Starter Issue Lvolling Antique Farm Tractors 1 08-11-2011 01:22:26 AM
John Deere B Starter parts trashman6062 Antique Farm Tractors 9 10-08-2010 05:23:14 PM
