Cleaning a Plastic Gas Tank?
this thread has 7 replies and has been viewed 398 times
Old 06-06-2019, 05:44:32 PM
Tracy T Tracy T is offline
Question Cleaning a Plastic Gas Tank?
i have a nasty and i mean real nasty fuel tank that needs a good cleaning but its plastic. so nasty it looks like tar in the bottom! any ideas what to use? normally i would take it to the radiator shop if it were steel, but this one is some form of plastic.
Old 06-06-2019, 06:42:00 PM
Default Re: cleaning a plastic gas tank?
I use denatured alcohol on metal tanks.Try a spot on the outside of tank to see if it affects it.
The Following 2 Users Say Thank You to Ed Radtke For This Post:
Old 06-06-2019, 06:48:17 PM
I have also been thinking, leave it out of the truck upside down in the sun and it may bake it to where i can take a rubber mallet to it and break it up. dont know if that will work or not.......
Old 06-06-2019, 08:04:49 PM
K-Tron K-Tron is offline
Put it in an ultrasonic cleaner without the heater on. It will be sparkling clean inside before you know it. If a cleaner is not accessible, pour some gasoline and some loose hardware, nuts, lockwashers into the tank and shake it like a morocca drum.
Old 06-06-2019, 08:48:26 PM
DustyBar DustyBar is offline
Originally Posted by K-Tron View Post
... pour some gasoline and some loose hardware, nuts, lockwashers into the tank and shake it like a morocca drum...
or just strap it to the rear wheel of your garden tractor and let it turn for an hour with a length of chain and hardware inside.
Old 06-06-2019, 08:50:52 PM
pour some MEK in there and let it sit. It will break the stuff up.
Old 06-06-2019, 08:54:23 PM
Monsonmotors Monsonmotors is offline
Pressure wash the inside is what the local radiator shops (that did gas tanks) always said. You can do it at the self-serve car wash if they don’t catch you.
Just about all the radiator shops are gone, darn it.
I recently had a gunk-filled metal tank take me a month start to finish on cleaning. I had to break out the gunk with a stick. Dump out chunks. Repeat.
Yuck! One of the WORST jobs antique vehicle enthusiasts face.
No fun.
The Following User Says Thank You to Monsonmotors For This Post:
Old 06-06-2019, 09:22:19 PM
LOL, you guys jarred some memory cells from my earlier days with your ideas! But hey thats a good thing!! blue, MEK, methal ethel keytone what you are talking about? we have a pressure washer on hand! fell out of the back of somebodys truck, best thing that has happened to me in a loooooong time!
black plastic fuel tank fungus sdowney717 Generators & Electric Motors General Discussion 13 01-28-2016 03:18:14 PM
Plastic gas tank repair ronny p 148 Farm Antiques and Collectibles 8 05-15-2012 07:41:16 AM
Gas Tank Cleaning peerless Hit & Miss Gas Engine Discussion 5 06-14-2010 11:33:23 AM
plastic gas tank repair CAnger Small Air Cooled Gasoline Engines 1 10-07-2006 07:12:02 PM
