Continental F-163
this thread has 2 replies and has been viewed 5648 times
Old 01-22-2005, 11:42:15 AM
Paul J. Morrison
Default Continental F-163
I would like to know the horsepower or torque available from this engine at 1800 rpm. I havent been able to fine a page with this rating, or for a ford 300 ind. engine. I would like to replace my y-112 on a 20k generator with the f-163 and also dont know the SAE bellhousing size of it.
Old 01-22-2005, 10:26:16 PM
Default Re: Continental F-163
For the Ford 300 six industrial engine, MOTOR lists it as from 226 ft pounds torque to 272 ft pounds @ 1800 which calculates out to 58 to 70 kW. The lower value they call "light duty" 1 bbl carb and the higher value is "heavy duty" 1bbl. The years were 1973 and 1974. I have a pump with the 300 six on it and I will see what the SAE bellhousing is tomorrow. The SAE bellhousing will be a separate piece made to fit the Ford engines
http://wahiduddin.net/calc/cf.htm is a calculator for hp and 0.75 x hp =kW
Jim
Old 01-23-2005, 03:28:21 PM
Ford 240 and 300 industrial engines list bellhousing as SAE 3 or 4, maybe there is a break between the two or some overlap. My pump has a non standard bellhousing and an adapter plate, so that was no help
I have seen generator sets from 50kw on a 240 Ford industrial engine to a 30kw on the 300.
Jim
Jim
Continental 15H Hubbie Antique Autos and Trucks 2 04-10-2018 05:27:49 AM
Continental AA7 bsaeland Small Air Cooled Gasoline Engines 12 02-18-2017 11:04:05 AM
AA 7 Continental J Kocak Small Air Cooled Gasoline Engines 1 03-08-2016 08:30:31 PM
Continental AU8? John Antique Engine Archives 1 08-18-2000 08:57:02 PM
