Re:exciter numbers
this thread has 5 replies and has been viewed 1912 times
Old 06-11-2005, 07:34:33 PM
Bobby B. Bobby B. is offline
Default Re:exciter numbers
Hi Billy Shafer.
The exciter numbers from my Onan 2cyl. diesel genny are: 209-5 and 04SX1N3B.I hope this helps.Thanks very much, bobby b.
Old 06-12-2005, 12:39:55 PM
Billy J Shafer's Avatar
Default Re: exciter numbers
Need your email address.Can not get file to post.
Old 06-12-2005, 07:06:52 PM
Hello Billy,
My e-mail is: lizzybee@ntl.sympatico.ca Would you know the polarity of the two exciter brush leads? Thanks, Bobby b.
Old 06-14-2005, 12:00:25 AM
Smile Re: exciter numbers
Hello Billy,
Received the exciter schematic and thank you ever so much.I appreciate you taking the time to help, and believe me, it will help immensely.I have tried to purchase the Onan factory manual for the genny end,but so far,all I can find is the manual for the 2 cyl. diesel.Any other genny info. would be greatly appreciated.Thanks again, Bobby B.
Old 06-14-2005, 02:47:50 AM
BTPost's Avatar
BTPost BTPost is offline
Are you sure that your Genend has brushes? Most of the DJx Series units
are equipped with Onan YD Genends, and these are brushless.
Bruce in alaska
Old 06-14-2005, 02:05:33 PM
Bruce in alaska
Hello Bruce,
Yes, indeed it has brushes.Pulled both bakelite brusholders off and ovalled out the center of the brushboxes to accept Chevy alternator brush springs.My brush springs were phosphor-bronze, had been hot at some point, and were soft as wet noodles.Made up a couple of brushes as well, and assumed this was my problem.It wasn't the only problem,since I still have no volts. Haven't had a chance to get back at it yet,to check my exciter wiring against the schematic Billy Shafer so kindly supplied since the wife has me installing an air conditioner.Next is the roto-tiller, then hopefully,I'll get back at the Onan. Bobby b.
Need 017A Exciter sarge155 Military MEP and Aircraft Gen-Sets 3 10-14-2017 06:00:17 PM
Connecting a DC Exciter JD840 Generators & Electric Motors General Discussion 8 05-31-2017 06:50:29 AM
Onan exciter don-mar Onan Generators 2 09-23-2007 05:19:10 PM
Exciter voltage ? Gus Simms Generators & Electric Motors General Discussion 16 04-08-2007 05:12:17 PM
Elliott exciter Jim Mackessy Generators & Electric Motors General Discussion 0 09-22-2003 09:29:46 PM
