porter-cable brushless alternator with capacitor
this thread has 6 replies and has been viewed 9559 times
Old 10-15-2005, 04:26:50 PM
Ronarm Ronarm is offline
Default porter-cable brushless alternator with capacitor
I recently purchased a porter-cable H4501S-W generator which has a brushless alternator with a 25Uf capacitor for field excitation purposes.
The alternator is not producing any 110/240VAC output and all of the stator and rotor windings and the capacitor are okay.
A check on a 1OKw porter-cable model has revealed that there is an additional capacitor in parallel with the one that is provided with the alternator.
I suspect that my alternator needs a higher capacitance value for field excitation so that a voltage can be generated but I am not sure what value to use. I would also like a wiring diagram which shows the connections between the alternator stator windings and the front panel which has the receptacles.
Ron
Old 10-15-2005, 08:04:41 PM
Default Re: porter-cable brushless alternator with capacitor
I doubt it is the capacitor if it checks good. If it has been sitting in storage for a while, it might need to be flashed to restore the residual magnetic field.
Look inside for 2 exciter leads which feed the stationary field of the brushless exciter. Usually it looks like a small stator and is mounted in the end of the main generator enclosure opposite the engine, with the rotating exciter field inside it on the armature shaft. There could be some numbering on the wires like F1 and F2 or maybe F+ and F-. Apply DC voltage from a battery of 6 to 12 volts observing correct polarity if known. leave the connection for maybe 10 seconds and then remove and start the engine. This process of flashing should be more effective with the engine running, but be very careful you do not get shocked when it excites. With it running, flash only for a second. It should make some voltage after the flashing procedure even if there is something wrong with the exciter or regulator. This minimal voltage is called the residual voltage, and if it is high enough the set should excite and make full voltage unless something else is wrong.
Old 10-15-2005, 08:53:38 PM
Thanks. I will check the capacitor again and if it is okay, I will proceed with your recommendation.
Old 10-17-2005, 01:45:34 PM
Jim,
Thanks very much for the good advice. After checking the capacitor and the rotating diodes and found that they were okay, I carried out the flash test on the stator field winding to restore the residual magnetism and I am now getting the correct voltages at the various receptacles.
Thanks again,
Ron Armstrong
Old 06-05-2014, 11:41:57 AM
joehelf joehelf is offline
Look inside for 2 exciter leads which feed the stationary field of the brushless exciter. Usually it looks like a small stator and is mounted in the end of the main generator enclosure opposite the engine, with the rotating exciter field inside it on the armature shaft. There could be some numbering on the wires like F1 and F2 or maybe F+ and F-. Apply DC voltage from a battery of 6 to 12 volts observing correct polarity if known. leave the connection for maybe 10 seconds and then remove and start the engine. This process of flashing should be more effective with the engine running, but be very careful you do not get shocked when it excites. With it running, flash only for a second. It should make some voltage after the flashing procedure even if there is something wrong with the exciter or regulator. This minimal voltage is called the residual voltage, and if it is high enough the set should excite and make full voltage unless something else is wrong.[/QUOTE]
I have a Porter CAble BSV 750 genset like the one described in this post. I cannot seem to locate the F+ and F- wires you mentioned. I have checked the stator windings and the rotor windings and the diodes on the rotor and the bridge rectifier but I am only getting 2 VAC at my receptacles. Will you help me to locate the excitation wires you mentioned?
Old 06-06-2014, 01:58:58 PM
I don't know how to attach photos yet but I will learn.
Old 05-30-2016, 06:39:33 PM
sc6lou sc6lou is offline
Hello,
I have the same generator. My son took the diodes off the stator and does not remember which way they were installed. They are mounted 180 degrees apart. Are the both mounted the same direction or different. Cathodes on the same side, like looking at them with one on top and one on bottom is the cathode to the left or right or both are opposite.Also there are either resistors or thermistors going across the diodes and I am trying to fine out the size or part number. Thanks for any information.
Porter Cable BSV 750-W Brushless Generator with NO AC output joehelf Generators & Electric Motors General Discussion 48 04-30-2019 11:35:44 AM
Brushless Alternator with Capacitor Jim McIntyre Generators & Electric Motors General Discussion 30 07-24-2016 10:22:03 PM
Porter Cable Chris Galloway Machine Shop and Tool Talk 11 07-18-2016 11:12:18 PM
Capacitor Excited Brushless Alternator zzdodge Generators & Electric Motors General Discussion 24 03-28-2015 07:26:50 PM
Porter Cable vern0n Garden Tractors and Mowers 4 01-29-2011 12:06:05 AM
