Manuals for large Onan generators?
this thread has 6 replies and has been viewed 2517 times
Old 01-10-2006, 07:19:20 PM
Jeffw5555 Jeffw5555 is offline
Default Manuals for large Onan generators?
I'm getting my recently purchased 75.0 ENT generator up and running, and purchased the UR service manual for it, thinking that it included the stuff that normally is in a service manual.
Turns out the manual only covers the alternator and controls. None of the other aspects of the system are covered. (engine & governor, for instance) It's got the 460 Ford turbo engine, which I am converting to LP from NG.
Didn't Onan make "proper" service manuals? I assume I have to get an indivdual service manual for the engine. (where would I get one?) How bout the governor? At this point I only have two really basic questions. How do you set engine speed? Is there a governor sensitivity adjustment?
Any advice is appreciated.
Jeff
Old 01-10-2006, 07:46:54 PM
EricWood's Avatar
EricWood EricWood is offline
Default Re: Manuals for large Onan generators?
Northern Power Products, Inc, is the OEM provider of Ford industrial engines to Onan. They provide very good engine service manuals. (for a price, of course )
2859 Lexington Ave S
PO Box21348
Eagan, MN 55121
(651)-452-8900
I'm guessing you're talking mechanical governor? The bolt/locknut combo that pushes down on the arm with the spring attached is your speed adjustment. Sensitivity is with the threaded-rod holding the spring snug. Using a heavy-load source (if you have one) adjust for the best frequency response (the most minimal loss in speed between no-load and full-load), and still have stability. If limited in sizable loads to apply, you can dial it in where you install it by setting the Hz to 60 while under the load it will normally carry. [Also, ensure the belt runs this governor is running fairly slack. Any appreciable tension, and you'll have a catastrophic governor failure at some point.
Old 01-10-2006, 08:05:42 PM
Billy J Shafer's Avatar
Yes Onan does have a manual for the ENT.I will post the number as soon as I can find mine.If you are looking for the engine manual you will have to go to Ford such as Northern Power.Onan only has engine manuals on engines they make.
Old 01-10-2006, 09:42:21 PM
Gunny Gunny is offline
How about full model, serial and spec number. What kind of governor? Mechanical or electronic?
Old 01-11-2006, 03:31:52 AM
Thanks for the replies. It is model 75.0ENT-15R/25282A, serial number K820641770.
It has a mechanical governor.
Jeff
Old 01-16-2006, 02:48:33 PM
Felicia Posey Felicia Posey is offline
i'm looking for a manual for onan 15.0 GenSet
Old 01-16-2006, 03:03:33 PM
Default Onan 15.0 GenSet
I need a owners manual or wiring diogram
Generators, Large Loads and Off Grid Living csareb Fuels and Alternative Fuels 21 05-31-2019 05:14:28 PM
Advice Needed Large Worthington & Fairbanks-Morse Diesel Generators 2Phargone Vintage Diesel and Oil Stationary Engines 13 02-06-2017 12:34:41 PM
Onan Generators for large 5th wheel RocklandValley Onan Generators 31 02-17-2016 09:35:46 PM
looking for manuals for onan generators stevo Onan Generators 1 04-26-2013 04:36:16 AM
Running a large DC motor from two generators? jlrsp3 Generators & Electric Motors General Discussion 19 06-28-2010 08:41:24 AM
