Newest Project (Bessemer)
this thread has 35 replies and has been viewed 4621 times
Old 04-26-2008, 11:07:23 AM
JKWidener's Avatar
JKWidener JKWidener is offline
Default Newest Project (Bessemer)
Well, here is my newest project engine I'm picking up tomorrow. I still need to find out what brand and model of magneto this engine takes. And also the factory colors. It is a 4hp Upright Bessemer with a serial number of B816. Anyone know the approx year of mfg?
ID:	32858   Click image for larger version
ID:	32859   Click image for larger version
ID:	32860   Click image for larger version
The Following User Says Thank You to JKWidener For This Post:
Old 04-26-2008, 03:57:56 PM
Ryan M Ryan M is offline
Default Re: Newest Project (Bessemer)
We have a 4hp Gaso kero bessemer with a water hopper cast in one piece with the cylinder. It has a serial number a little lower than yours (but I can't remember what it is right now). Ours has a sumpter high tension magneto. I have not been able to find out any dating for these engines. Our runs real nice and slow. Ours is unrestored and is mostly a dark color maybe black at one time with what looks like some red on the battery door maybe it was a primer.
Ryan
Old 04-26-2008, 04:47:17 PM
JKWidener's Avatar
Ryan, this sounds like the above mentioned engine. Any chance of getting any pictures?
Old 04-27-2008, 03:54:37 PM
I have the pictures on my work computer. I will post them up tomorrow.
Ryan
Old 04-27-2008, 04:59:40 PM
JKWidener's Avatar
ok, thank you very much
Old 04-27-2008, 06:35:45 PM
John Dungan John Dungan is offline
Was this type of Bessemer a copy of the detroit 2 cycle engine?
It certainly looks similar.
Regards,
John
Dublin-Ireland
Old 04-27-2008, 06:55:20 PM
JKWidener's Avatar
yes, has something with bessemer buying out detroit, or something along those lines.... Im still doing research, but im sure someone will step in and correct me, Or i hope they will...lol
Old 04-28-2008, 01:37:21 PM
Here are the pictures (I hope)
Ryan
ID:	32948   Click image for larger version
The Following 4 Users Say Thank You to Ryan M For This Post:
Old 04-28-2008, 04:23:57 PM
JKWidener's Avatar
there is some resemblence, but alot of differences also... Thanks for the pictures, is there a chance i could get you to get me close up pictures of where the magneto attaches to the gearing. Mine has a gear in that spot, and i dont think that is original..
Old 04-29-2008, 09:35:59 AM
John Davis's Avatar
John Davis John Davis is offline
John,
Looks like you have found the answer to what kind of magneto your engine should have. That mag looks to be original on Ryan's Bessemer. Same gear mechanics as yours I believe.
Ryan I have never seen a vertical hopper cooled Bessemer before. I seen a air cooled vertical Bessemer here a while back that was for sale on Harry's classifieds. Did you know that your engine has a attachment on it for running on natural gas? John's engine has the same attachment also. Thats it next to the air intake valve and governor arm. Very nice looking engines guy's.
Here's some info on these two cycle type engines
In 1910 Ben J. Middleditch started manufacturing and selling a stationary two cycle engine
very similar in design to the Detroit Engine Works vertical two cycle engines. The engines brass tag was embossed with the Middleditch Engine Company name.
In 1913 Bessemer Gas Engine Co. purchased the Middleditch Engine Co. Bessemer continued producing the two cycle vertical engines into the 1920's. Benjamin J. Middleditch died May 22, 1916.
Ben J. Middleditch manufactured the first fuel reservoir and injector for Detroit Engine Works. Peterson Bros designed it and patented it.
Early made Bessemers had one piece cylinder and head, later models had two piece, cylinder and bolt on head.
More information is available on the website below
http://www.antiquengines.com/Detroit...Works_Menu.htm
The Following User Says Thank You to John Davis For This Post:
Old 04-29-2008, 12:53:25 PM
John, thanks for the info. I have always wondered why the engine had that extra little intake, now I know.
Ryan
Old 04-29-2008, 01:25:15 PM
Steve Kunz's Avatar
I have a 4hp. Bessemer that my father got from the original owner. The original owner said he ordered it from Middleditch and when the engine arrived it had a Bessemer tag on it. Ill try to get some pictures later but it is kind of buried with other junk, I mean antiques right now.
Old 04-29-2008, 03:00:23 PM
John Davis's Avatar
I'm in the process now of scanning and posting a complete catalog manual on the early vertical two cycle Bessemer's on my website. I have about half of the catalog posted. I will try to finish it this week. It has one page that talks about the natural gas attachment. I have two original two cycle vertical Bessemer catalogs and neither one of them show a hopper cooled or air cooled Bessemer's but we know there are a few. Catalogs show all tank cooled engines.
Steve what you said is very possible because I'm sure there was a certain amount of time it took for the transition from Middleditch Engine Co. to Bessemer Engine Co.
Old 04-29-2008, 05:41:44 PM
JKWidener's Avatar
Ryan, could you get the model and type, of the magneto for me, so i know what to look for. Thanks Alot for everyones help...
Old 04-29-2008, 08:17:08 PM
JKWidener's Avatar
From what i can see in the pictures, it is a "Type H" is this correct?
Old 04-30-2008, 12:23:32 PM
The engine is at my fathers house so It may take me a couple of days to confirm what the magneto is. In the picture I have it looks like HLB or HUB. I have also seen them with other magnetos as well. I talked with a guy from Pennsylvania a while back who had several of these engines and had a lot of info on Bessemers. I will try to find out what other magnetos came on these engines.
Ryan
The Following User Says Thank You to Ryan M For This Post:
Old 04-30-2008, 05:18:08 PM
Siz Siz is offline
Hello JK
if you go to ebay.com.au there is a Sumpter magneto for sale over here,item no 320246516905
Siz
The Following User Says Thank You to Siz For This Post:
Old 04-30-2008, 05:39:58 PM
JKWidener's Avatar
Thanks for the tip, but it is only a 2 bolt mag, i need a 4 bolt.. Thanks for the tip...
Old 05-01-2008, 05:05:31 PM
Siz Siz is offline
Hello JK
not sure if you saw this one,item no 320245693495
on ebay.com.au
Siz
Old 05-01-2008, 07:27:14 PM
JKWidener's Avatar
Well, i had time to work a little on the Bessemer tonight. Got the natural gas / air intake valve body off and both valves are stuck. Wont take much to unstick them but might need to make new stems. Got the governor moving like it should and also got a closer look at that magneto gear, the gear has been added in the past. It should just be a shaft sticking out, for the magneto to join to. The gear will be removed and the correct setup re-installed. What was the original color of these engines? After carefully cleaning the valve body, there is, what appears to be red or orange paint.... Well, more work tomorrow...
my newest toy. Dave Beck Hit & Miss Gas Engine Discussion 18 12-05-2005 03:33:18 PM
Just got my newest engine running. David OBrien Hit & Miss Gas Engine Discussion 0 05-13-2005 09:20:55 PM
My newest find Doug Waggonner Hit & Miss Gas Engine Discussion 5 04-24-2005 10:45:40 PM
Newest find Tom Winland Hit & Miss Gas Engine Discussion 13 02-01-2005 10:57:22 PM
