Alternator for Low Wind Speed Wind Turbine.
this thread has 3 replies and has been viewed 4576 times
Old 05-15-2008, 11:42:45 AM
mechamz mechamz is offline
Default Alternator for Low Wind Speed Wind Turbine.
Hi,
Anyone know is there any alternator for low wind speed wind turbine?
My wind speed is around 2m/s to 4.4 m/s, and the alternator have to generate 50W.
It can be aided with gear ratio.
anyone have any idea?
Old 05-15-2008, 12:56:51 PM
Don Smith
Default Re: Alternator for Low Wind Speed Wind Turbine.
I have seen a number of designs that used a homemade alternator using an automotive hub with disk brake rotor. The rotor had a circle of super magnets (easily obtained) glued to the rotor. A number of coils were wound, using 16 ga. wire, around plastic bobbin. Some used a soft iron core, some did not. Very slow speed and high current at 12/24 volts.
If you use an automotive alternator I would suggest a power belt or fiber/plastic gears for silent service.
Another suggestion might be the DC motors used in tape transports and even treadmills. Many are good for up to 90 volts and 10 amps or better. Food for thought Don Smith
Old 05-15-2008, 06:26:29 PM
Email NOT Working
I've seen plans using Fischer Paykel DC washing machine motors.
They use DC motors and change direction to agitate with no transmission.
Kevin
Old 05-15-2008, 08:16:49 PM
go to www.otherpower.com and be prepared for a lot of reading
Wind Charger paulworden Solar and Wind Power for Home, Farm & Industry 15 06-13-2016 12:31:59 AM
WIND WHEEL Engine Pacrat Oil Field Engines & Related Equipment 6 05-30-2008 08:49:25 PM
Wind Wheel Engines Russell Farmer Oil Field Engines & Related Equipment 0 10-24-2006 09:51:23 AM
Wind Power Gen. Andrew Generators & Electric Motors General Discussion 2 03-31-2004 12:48:42 AM
