Alternator for Low Wind Speed Wind Turbine Needed
this thread has 3 replies and has been viewed 10555 times
Old 05-22-2008, 07:54:57 AM
mechamz mechamz is offline
Default Alternator for Low Wind Speed Wind Turbine Needed
Hi,
I'm finding an alternator which is able to generate 40-50W, but under low rpm.
Anyone can kindly give me a suggestion?
Old 05-22-2008, 08:15:26 AM
Default Re: Alternator for Low Wind Speed Wind Turbine Needed
Are you trying to go with direct drive? A cogged belt like a timing belt on an automobile would give an efficient, quiet, maintenace free speed increase, you could use a small automotive alternator.
Old 05-22-2008, 09:53:56 AM
K D Redd K D Redd is offline
What type of wind turbine are you using? Stewart, Savonuse or other. Most alternators including auto alternators need to be turned at a fairly high RPM to make power. The only slow turning alternators are ones wound with MANY poles to make AC power with an external exciter which are diven at a CONSTANT speed. You will not have a constant speed with wind. You will need to generator DC current to charge battery and then use an inverter to make AC. You might be better using a DC genertor that self-excites when the wind come up to charge a battery bank. This way you would not have to have a switch, a zero speed switch, that would excite the alternator when the wind came up because you can not have the alternator energized all of the time as this would be a lost of energy. You will need to look into some type of gearing system to speed up the relative high torque/ low speed from your wind turbine to the high speed/ lower torque need for a alternator or generator.
You might also look into a permanent alternator like some of the older British motorcycle used but if you use something like this you will have to deal with VERY high output in high wind situation that could damage you battery storage system. I guess what I am trying to say is,IF IT WAS IF IT WAS SIMPLE WE WOULD HAVE SYSTEM LIKE WHAT YOU ARE WNATING EVERYWHERE BY NOW.
Kent
Kent
Old 05-22-2008, 11:20:05 AM
Email NOT Working
What JB mentions would naturally give you a two to one ratio, but you could possibly mix and match brands for different size toothed belt cogs.
On Evilbay, there is an outfit in Kansas that has some interesting wiring/controls for a homebuilt wind generator. They call it "Breezy 5.5" and also sell plans and kits. I don't know a lot about these, but they seem to have a lot of good information and ideas. It uses juice from the pole to excite and therefore doesn't backfeed in case of a power outage. Linemen love that feature. It also freewheels until it gets up to speed and then kicks in until it slows down- (if I understood correctly)
Kevin
Wind Charger paulworden Solar and Wind Power for Home, Farm & Industry 15 06-13-2016 12:31:59 AM
Alternator for Low Wind Speed Wind Turbine. mechamz Generators & Electric Motors General Discussion 3 05-15-2008 08:16:49 PM
Wind Power Unit Ihorse Solar and Wind Power for Home, Farm & Industry 1 12-12-2005 11:08:35 AM
Wind Power Gen. Andrew Generators & Electric Motors General Discussion 2 03-31-2004 12:48:42 AM
Help I.D. Ontario wind engine David Heggie (qc-cda) Antique Engine Archives 1 05-09-2003 12:14:52 AM
