Nice example of recirculating coolant
this thread has 7 replies and has been viewed 2476 times
Old 08-12-2014, 10:54:20 PM
Fred Van Hook's Avatar
Photo Nice example of recirculating coolant
Randy really has a nice setup demonstrating how to circulate water without a pump..
http://youtu.be/DaJdP7BxtT0
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following 7 Users Say Thank You to Fred Van Hook For This Post:
Old 08-13-2014, 09:29:26 AM
Default Re: Nice example of recirculating coolant
OK, I give up - what makes it circulate? I see a check valve in there. This isn't standard thermosyphon, is it?
Kevin
Old 08-13-2014, 11:22:15 AM
Bob Willman Bob Willman is offline
Intake vacuum pulls water into the vertical pipe past a check valve. I think gravity then pulls water through the engine. I saw this the first time at Oblong. The engineer said that adjusting the valve that controls how much water enters the vertical pipe without sucking it into the engine intake valve was critical.
Bob
WB8NQW
Old 08-13-2014, 08:48:25 PM
con-rad con-rad is offline
Interesting, though i'd imagine that a water pump or thermosyphon would be a little simpler.
in regards to sucking water in the intake... perhaps if there was a diaphragm between the intake vacuum and water? it would still pump the water but prevent hydrolocking...
conrad
Old 08-14-2014, 08:49:20 PM
tyrion's Avatar
tyrion tyrion is offline
The system uses 3 check valves, 1 in the line coming from the bottom of the cooling tank, this ck lets water be sucked from the cooling tank into the bottom of the engine's cooling system, but won't let the water go back in the bottom of the cooling tank. The second ck valve is in the verticle pipe coming up and out of the engine's cooling system. The engine's vacumn on the intake stroke draws the water from the cooling tank up thru the cooling system and up over the second check valve and up past the tee in the verticle pipe a foot or so. When the intake stroke is over the vacumn on the water is released and the water wants to seek its level in the cooling tank, it then runs thru the third check valve in the horizontal line and makes it's way back to the cooling tank. The key to this working correctly and not flooding the engine intake, is a little 1/2" plug valve that ties in to the top of the piping loop that ties the engine intake into the verticle coolant pipe, this little valve is the vacumn breaker for the system and allows the water to drain back to the coolant tank when the engine is not on the intake stroke.
This system is used on both of the working powers at Flatrock and both of the display powers at the Oblong show.
I hope that my explanation of this system are understandable, It is a wonderfully simple cooling system!
Randy
The Following User Says Thank You to tyrion For This Post:
Old 08-14-2014, 10:21:50 PM
Photo Re: Nice example of recirculating coolant
Randy it was nice seeing you at Oblong! Thanks for bringing it..I was really impressed seeing the cooling system installed on your engine!!!
Name:	Oblong Pics 2014 053.JPG
Old 08-15-2014, 05:31:13 AM
tyrion's Avatar
Thank you Fred for the great videos and pics you post! See you at the next show!
Old 08-18-2014, 09:23:47 AM
Owen Bosma's Avatar
Owen Bosma Owen Bosma is offline
The same system is used of on some engines to pump fuel from a lower tank to the carb.
http://www.smokstak.com/forum/showthread.php?t=54562
.......... Owen
http://home.cogeco.ca/~obosma
James Bosma You Tube
The Following 2 Users Say Thank You to Owen Bosma For This Post:
RJC Coolant Daverepair Onan Generators 5 02-25-2013 11:48:00 PM
RDJC Coolant Recomendation? KD5BYB Onan Generators 6 05-09-2011 12:37:32 PM
Coolant Query Major Tom Onan Generators 8 01-14-2011 10:19:33 AM
Coolant Change Procedure caymann Onan Generators 3 03-03-2009 04:36:11 PM
Tig Torch Coolant Question Lisa Johnson Welding Shop 6 04-11-2008 06:10:31 PM
