I.H.C. LA and LB Valve Covers
this thread has 2 replies and has been viewed 1630 times
Old 09-14-2002, 12:33:04 AM
Charlie Bryant
Default I.H.C. LA and LB Valve Covers
Rick Rohrs just posted an add for valve covers for the 1 1/2 - 2 1/2 HP I.H.C. LB engines. Correct me if I am wrong. The valve cover for the 1 1/2 - 2 1/2 HP I.H.C. LA engines is smaller than for the 3 - 5 HP I.H.C. LA engine and the LB engines. But the valve cover for the 1 1/2 - 2 1/2 HP and the 3 - 5 HP I.H.C. LB engines is the same. Also the valve cover for the 3 - 5 HP I.H.C. LA engine is smaller than the one for the LB engines. At Portland show I sold a cover for an LA engine that I told the guy it was for a 1 1/2 - 2 1/2 HP LA engine. I think I might have been mistaken and it was for a 3 - 5 HP LA engine. If so and the fellow reads this message please contact me.
Old 09-15-2002, 12:14:51 PM
Ed & Hit & Miss Enterprises
Default Re: I.H.C. LA and LB Valve Covers
Charlie-All four valve covers are different. The LB covers are the same physical size the the 3-5 is cut out more so you would have a gap is put on a 1 1/2HP model. The LA covers are different sizes. Good Luck-Ed
Old 09-15-2002, 06:05:27 PM
Charlie Bryant
Thanks a lot Ed. I have 2 covers for an LB. Guess I will take them to Cool Springs to see which engine they are for. See you there.
Charlie
Oil Leak on rocker covers flagmaster Onan Generators 6 04-04-2010 08:53:00 PM
Engine Covers JKWidener Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 10-17-2007 06:40:51 PM
tractor seat covers casertractor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 04-24-2006 01:01:44 PM
Are there any canvas covers available? Karl T Schwab Hit & Miss Gas Engine Discussion 2 05-24-2005 11:40:17 PM
