Welding Shop
Miller AEAD-200LE welder-generator
this thread has 2 replies and has been viewed 7356 times
Old 10-16-2010, 09:20:36 PM
Lil Joe Lil Joe is offline
Default Miller AEAD-200LE welder-generator
I bought this unit new in 1984 and it been trouble free. With all the bad weather in the past ten months the generator has had a lot of use when the power has been off, days at a time. Now the generator output seem to be lacking when the furnace blower kicks on. It's rated at 5kva and I didn't have very much on line. I use # 12 romex cable for power cord. This problem has just started. Before I take the cover off, does anyone have any experience or have any tips on what to look for. Thank You. Lil Joe
Old 10-17-2010, 12:45:44 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: Miller AEAD-200LE welder-generator
Check the output voltage. Is the fine current control set to 10? Idle speed at 1860 RPM? The AC generator side has a voltage regulator board, if it's gone bad your output voltage will be around 95-105 volts instead of around 120. Slip rings cleaned since you got it 26 years ago?
The Following User Says Thank You to OnanParts For This Post:
Old 10-17-2010, 01:35:22 AM
Onan Parts, thank you for giving me a place to start. I kept the oil and filter changed, plug and wires and new coil, but have done nothing to the generator. I did have the dial on 10 and the rpm's were 1850. I haven't taken the cover off to check anything, My electrician had his knee operated on so I was waiting. I will check the slip rings and connections for corrosion etc. I'm supposed to have my wrist operated on, but I'll get back to you. Lil Joe
---------- Post added at 01:35 AM ---------- Previous post was at 01:33 AM ----------
I forgot, the voltage was 114 volts.
Miller Blue star 2E OR AEAD 200LE bobgil Welding Shop 3 05-12-2010 09:31:48 PM
Older Miller Welder/generator badspell48 Welding Shop 1 04-06-2010 12:49:17 AM
Miller welder/generator help please. envelopes2007 Welding Shop 4 03-24-2010 02:39:32 PM
Miller AEAD ~Wittes-End~ Onan Generators 2 08-31-2009 04:35:31 AM
Miller AEAD-200LE: Engine options ASavage Onan Generators 6 11-15-2006 12:05:41 AM
