Welding Shop
TIG set up for my Miller AEAD 200LE?
this thread has 2 replies and has been viewed 3867 times
Old 11-12-2010, 12:24:46 PM
cweaver7018 cweaver7018 is offline
Default TIG set up for my Miller AEAD 200LE?
I have two aead 200 le welders that run great. I really need a TIG set up that will operate off the welder. I would like to be able to weld aluminum and stainless. I really want to make sure that what I buy is compatible with the welder. Any and all suggestions will be appreciated. Part #'s, web sites, personal experience, anything and everything Please.
Thank you
Chris Weaver
DPI Welding
dpiwelding.com
Old 11-12-2010, 08:03:35 PM
feeln blue feeln blue is offline
Default Re: TIG set up for my Miller AEAD 200LE?
well, first you can get an air cooled tig torch on ebay or go to millerwelds.com, to weld alumium you will need a high frequency box, also available on ebay or millerwelds.com, problem is there is no way to control amperage like with a foot pedal or thumb wheel on the torch cuz nothing plugs into the old 200le. you may want to sell your 200le and upgrade to a bobcat which you can plug tig attachments into no problem.
The Following User Says Thank You to feeln blue For This Post:
Old 11-13-2010, 10:22:45 PM
ciggs ciggs is offline
I would go with a water cooled torch set up for aluminum if it's going to be used for any lengthy time or heavy applications, if it's just smaller stiches air cooled is fine,
The Following User Says Thank You to ciggs For This Post:
Trying to find out what kind of onan engine is on my AEAD-200le? Need gasket kit. cweaver7018 Onan Generators 6 10-26-2010 11:09:47 AM
Trying to find out what kind of onan engine is on my AEAD-200le? Need gasket kit. cweaver7018 Welding Shop 1 10-23-2010 05:47:00 PM
Miller AEAD-200LE welder-generator Lil Joe Welding Shop 2 10-17-2010 01:35:22 AM
Miller Blue star 2E OR AEAD 200LE bobgil Welding Shop 3 05-12-2010 09:31:48 PM
Miller AEAD-200LE: Engine options ASavage Onan Generators 6 11-15-2006 12:05:41 AM
