Old Tecumseh replacement coil question
this thread has 4 replies and has been viewed 2159 times
Old 12-06-2011, 12:02:56 PM
Bigjoedo's Avatar
Bigjoedo Bigjoedo is offline
Default Old Tecumseh replacement coil question
Hello,
Bought a coil STENS P/N 460-063. The Spark plug wire is not installed.. Looking in the hole there is a point. Do I just stick plug wire into hole and hope the point pierces the copper core? Not sure I trust that type of connection? Thanks
Bigjoedo
Old 12-06-2011, 12:45:01 PM
sprkplug sprkplug is offline
Default Re: Old Tecumseh replacement coil question
The point that you see... is it threaded? A lot of times the coil literally "screws" into the wire.
The Following User Says Thank You to sprkplug For This Post:
Old 12-06-2011, 02:17:22 PM
KD5BYB's Avatar
KD5BYB KD5BYB is offline
That's the way one of my Fairbanks Morse magnetos on my Wisconsin AB was set-up. The post was threaded, and I pushed the wire in as I twisted. Made a surprisingly good connection.
thanks,
ben
The Following User Says Thank You to KD5BYB For This Post:
Old 12-06-2011, 06:00:46 PM
gvasale gvasale is offline
today the push-in-place connection is somewhat common. It has been for a number of years as well.
Old 12-06-2011, 07:07:07 PM
K D Redd K D Redd is offline
The Tecumseh coil from STENS has a threaded contact for the spark plug wire. You screw the plug wire into the coil. The stock Tecumseh coil had a pin the the plug wire pushed on to. Because this was a push on terminal, the wire was also glued into the coil.
Kent
The Following User Says Thank You to K D Redd For This Post:
B&S 2HP 60102 Coil replacement gbaumgratz Small Air Cooled Gasoline Engines 12 08-12-2018 11:47:35 AM
Maytag 72 coil replacement Mark Bruto Maytag Engines and Collectibles 56 09-12-2016 04:33:55 PM
SA 200 shunt coil replacement ? cub102 Welding Shop 1 05-16-2011 11:03:07 AM
Tecumseh HS50 twin shaft engine replacement Kestas Small Air Cooled Gasoline Engines 9 03-19-2011 09:49:33 PM
Replacement coil for CCK BBerg Onan Generators 3 02-21-2008 09:43:27 PM
