Fairbanks Morse ZD 2hp
this thread has 1 replies and has been viewed 1679 times
Old 12-16-2011, 11:21:47 AM
doc8246 doc8246 is offline
Default Fairbanks Morse ZD 2hp
How much oil does the crankcase hold on my FM 2hp zd? The dipstick does not have a stop on it so i don't know how far to push it into the dipstick tube. Thanks Ron
Old 12-16-2011, 02:17:57 PM
34 40 34 40 is offline
Default Re: Fairbanks Morse ZD 2hp
Maybe this'll help. From the manual..
OPERATING INSTRUCTIONS
6. Before Starting the Engine - (a) Remove the oil gauge rod and plug in the crankcase cover and pour in approximately one quart of engine lubricating oil (Medium for summer, Light for winter). Replace the gauge plug and rod. The oil should register at the "FULL" mark on the rod. Do not fill above this mark. (b) Fill the fuel tank with gasoline (approx. 3 quarts). (c) Fill the water hopper (approx. 2 gallons). Hot water will assist starting in cold weather.
---------- Post added at 01:17 PM ---------- Previous post was at 01:07 PM ----------
Since I am also a new owner of a Z I also have a thread going, almost the same title as yours! Check it out, look down this page and I'm sure you'll see it! Some good links in there too!
The Following User Says Thank You to 34 40 For This Post:
Fairbanks Morse N or NB? DirtbikePilot Hit & Miss Gas Engine Discussion 9 03-22-2012 08:42:19 AM
Gas cap for 6hp Fairbanks Morse kevincw Hit & Miss Gas Engine Discussion 2 07-06-2011 07:15:17 AM
Fairbanks Morse 1 1/2 hp ZA HLP Enar Drugge Hit & Miss Gas Engine Discussion 3 11-20-2010 06:23:13 PM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Hit & Miss Gas Engine Discussion 4 09-12-2008 11:03:58 AM
Fairbanks Morse T James Elenbaas Hit & Miss Gas Engine Discussion 3 06-02-2005 10:36:09 PM
