onan 4.0cck-3CR/1R resurrection and questions
this thread has 20 replies and has been viewed 2208 times
Old 07-26-2014, 08:27:25 PM
jdknech jdknech is offline
Default onan 4.0cck-3CR/1R resurrection and questions
SERIAL# 0475937973
hey guys! -my, what a TOUGH engine..
well this story starts back in the 70's there was a military base about a 1/4 mile from my house that closed down.. every building had a backup gen-set, and when the base was vacated everything was left.. well fast forward to 2014 and one of the buildings was turned over to the local police for a new sub-station, and i was able to acquire the gen fron the building.. the dowside- every spring the building goes underwater for 2-10 days.. so when i got it, I figured it was a lost cause.. the cylenders were packed full of mud, and the valves were all stuck..
so i pulled the heads, and cleaned it all up, and got it all freed up, put oil in it, and jumped the starter and it turned, but no fire.. and not enough to power to turn it over with plugs in it.. I cleaned the brushes, and found the "rope start" function, and with some ether it FIRED UP!!! rebuilt the carb and it now runs on its own and makes power!
now the issues- when it had water in it, it cracked the oil pan.. so it leaks out about a quart of oil every 5min.. where can i find a replacement? and will any other pans work, or just the cck pans?
also, the control board is fried.. the start circuit does not work, and there is components missing from the circuit board.. i will not need the charging circuit in the applcation I'm going to be using it in, so is there a cheaper/easier way to fix this other then the $150 flight systems board, or is that my best bet?
thanks for any help you guys can provide! -Joshua
Old 07-26-2014, 08:34:55 PM
Default Re: onan 4.0cck-3CR/1R resurrection and questions
Some pics of the gen, and what I'm using it on.
Old 07-26-2014, 08:38:07 PM
and I can only do one pic at a time?
Old 07-26-2014, 08:40:57 PM
Last one for today
Old 07-26-2014, 08:43:18 PM
Billy J Shafer's Avatar
You should be able to have the pan repaired. They do show up on ebay at times. There is a conversion kit for the board. We can send you the print for it. You can make your own.
Old 07-26-2014, 08:48:30 PM
That would be MUCH appreciated! the email is Jdknech@yahoo.com
and I was not sure if the pan could be fixed being that it is cast.. but I will run it by the local welding shop and see what they can do with it.. thanks again! -Joshua
Old 07-26-2014, 08:50:31 PM
Kpack
I've got a 4cck spec r I bought cheap and will part it out. Pm me.
Old 07-26-2014, 09:06:48 PM
JohnnyC JohnnyC is online now
Wow! Amazing how many of the old Onan gen sets that took a beating and look like they were in a train wreck in hell seem to fire up with some TLC. In your case were the cylinders were packed with mud and valves stuck fired up with a little elbow grease. I wonder if any of today's Chinese made generators would fire up after going through that same torture that your gen set went through.... let me take a guess..... I think my answer is NO.
JohnnyC
New Jersey
Old 07-26-2014, 09:24:44 PM
PM sent! thanks
---------- Post added at 09:24 PM ---------- Previous post was at 09:17 PM ----------
JohnnyC
New Jersey
I have found that older stuff was built to a spec that we seem to have lost in todays world.. most people want to throw out the old, and in with the new... but NOT THIS GUY! lol I would rather have one piece of machinery that lasts many years that i can maintain, then something that is "sealed" for life.. because it just doesn't last.. unfortunatly quality went out the door for quantity
The Following 2 Users Say Thank You to jdknech For This Post:
Old 07-26-2014, 10:45:17 PM
At one time I had five of the Chinese gensets in my shop. All with less than 50 hours on them. Two with less 5 hours. All beyond repair.
Onan 4.0CCK-3CR/12015P introductory questions KidDynamo Onan Generators 15 11-06-2018 05:17:22 PM
Onan 5.0 CCK setup questions Shmeefer Onan Generators 27 08-12-2015 10:04:06 PM
onan 4.0cck-3cr/20915v wiring questions michaelj Onan Generators 6 08-05-2013 09:48:52 PM
Onan 5.0CCK comments, observations and questions, handyhiker Onan Generators 33 01-31-2012 09:33:40 AM
Onan 5.0cck questions Powerman Onan Generators 11 01-28-2008 07:17:58 PM
