Go Back   SmokStak > SmokStak® Support and Information > Smokstak Forums Meet and Greet
Smokstak Forums Meet and Greet Welcoming Smokstakers New and Old, a place to say a bit about yourself and post a photo if you're really brave. If you have a technical question, please post it on one of our other boards.
McCormic Deering 1 1/2 hp cylinder binding
this thread has 6 replies and has been viewed 1660 times
Old 02-07-2012, 03:56:25 PM
Tim Cline Tim Cline is offline
Default McCormic Deering 1 1/2 hp cylinder binding
New to this site, so here goes. Have a 1 1/2 hp mccormick deering with wico mag ign. Was running great, until fuel pump came loose and broke. Sat for 3 yrs. Finally got new pump and a feww other minor items. Now it's together,seems to be binding (hard spot) when spinning over. Disconnect rod from crank, everything is fine. Reconnect,binding starts.rod bearing is correct,with plenty of oil and grease on all. Help!!!!!!!!!!
Old 02-07-2012, 08:30:52 PM
Elden DuRand's Avatar
Images: 6
Default Re: mccormic deering 11/2hp cylinder binding
Tim:
If the binding is in the cylinder, it could be rust on the cylinder wall or rings stuck in the grooves while the piston sat in the big portion of the bore.
It's probably not much of a problem as long as the binding isn't very heavy.
If nothing else, pull the piston out and find the problem.
Take care - Elden
http://www,eldensengines.com
Take care - Elden
http://www.eldensengines.com
Old 02-08-2012, 08:09:50 AM
Have had piston out twice. Rings look very good,honed cylinder twice.every thing is clean, with plenty of oil. Binds at back of throw.did not do this before fuel pump broke. Have recentered rod to crankshaft.thought it was fixed, not. I am missing something.thanks for any help.
Old 02-08-2012, 09:13:58 AM
pjjms pjjms is offline
If its binding in the cylinder area and its not the piston or rings than it can only be the small end binding. I know you say its free with the big end off but have you checked the following?
Are the valves sticking?
Is the cam shaft bent? I think this may also drive the fuel pump and if its had a prang in the pump maybe something is not right here.
More likely I wonder if the crank may have tweaked a little when it pranged causing the big end to bind in one spot when its all assembled? The flywheels are a lot of weight to stop in a hurry when something goes wrong and the cranks are soft. What happens if you slacken off the big end bolts just one turn from tight and rotate the engine?
The Following User Says Thank You to pjjms For This Post:
Old 02-08-2012, 09:44:45 AM
If i disconnect rod from crank, turns freely. When connected and properly shimed,it binds at end of throw.spraying oil at back of piston,it doesn't bind as bad. Drip oiler is working fine.did not have any water in hopper while it was sitting. Can't spin fast enough to start before binding starts.
Old 02-08-2012, 10:57:52 AM
Images: 6
If the wrist pin end of the rod is hitting the pin boss of the piston, it can cause the big end to bind on the crankshaft.
If you haven't already done so, you might try loosening the mains and shifting the crankshaft so the wrist pin end of the rod is centered between the piston bosses.
Interesting.
Take care - Elden
Take care - Elden
Old 02-08-2012, 11:29:27 AM
Will try it. I have had both flywheels off before. I did loosen both again,and try to center rod that way. Turned freely, thought i had it fixed. Not. Will try you're sugestion. Post later.
McCormic Deering T-20 fan belt mdirtycreek Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 02-10-2012 10:08:09 PM
1927 McCormic Deering? Polaraman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-04-2011 12:20:04 AM
3-5hp McCormic Deering TheToolman Antique Gas Engine Discussion 6 06-20-2008 07:08:32 AM
McCormic-Deering W12 Rob Karl Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 09-05-2006 08:13:23 PM
McCormic Deering Bryan Antique Engine Archives 1 04-24-2001 07:00:11 PM
