Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar 25 Rusty Restoration
this thread has 215 replies and has been viewed 45753 times
Old 08-03-2012, 09:02:53 PM
Default Caterpillar 25 Rusty Restoration
I have been working on a Cat 25 for about 4 weeks and decided to post a few pics of the job. I purchased this tractor on Long Island, NY about 16 years ago and it was complete but rough. The bottom was completely shot and most of the tin in sad shape. Finally after years of looking a Cat 20 parts tractor was located with the parts I needed to complete the 25. Although there are some differences many of the main parts like the tracks and bottom end will work. The 25 is a fairly unusual model with about 620 made in 1932. I have always liked this model series 20-25-28 because they are the last of the lod style ngas Cats. The engine harks back to the earlier 30's and 60's because the engine has individual cylinders with a one piece head holding it all together. It just has a neat old look. The pictures that will follow show the steps I am taking to get this unit mechanically solid but I will not be painting anything on the tractor. I find people love the old look and it is a lot simpler to do the job. I will be coating everything with Owatrol Marine Oil that has been mentioned on other threads over the years.
First pic is an overall view before anything has been done
Next shows how bad the tin work was that will all be replaced with rusty 1/8 metal. It has been outside for 4 years Perfect.
This pic shows a side view of the tractor showing condition of the tracks and track frames and finally the rusty condition of the gas tank surrport which is always a problem on this series.
ID:	141343   Click image for larger version
ID:	141344   Click image for larger version
ID:	141345   Click image for larger version
Old 08-03-2012, 09:39:04 PM
John C Walker John C Walker is offline
Default Re: Caterpillar 25 Rusty Restoration
I see a few other crawler tractors peeking around corners. Come on show us what ya got hidden away.
Old 08-03-2012, 10:03:12 PM
John I have about 65 Crawlers in the yard which I have collected over the past 20 years. I specialize in Fordson Crawler conversions [Have 10]but also have a lot of rare units like Model 35 bates Steel Mule and a 1925 Bear made in Boston. My motto is "Anything on Tracks".
The four pics here show the terrible condition of all the tin parts. once it was all cut apart and flattened it was used to make new ones using the old as templates. All the flat metal took 21/2 days to remake. pics to follow.
ID:	141353   Click image for larger version
ID:	141354   Click image for larger version
ID:	141355   Click image for larger version
Old 08-04-2012, 12:05:17 AM
We could always play I SPY. I spy with my naked eye a McD T series!
Old 08-04-2012, 08:10:55 AM
I have a few minutes to ad a few pics of the Cat..
The first shows the typical damage to the gas tank bottoms caused by sitting in a saddle that holds water and leads to severe rusting.. I will just cut the bottom out,sandblast the inside and put in new bottom. Last 3 pics show the real rough condition of the trackframes and side frames.. The are a bolt together setup and I will make new outer rails by drilling out new 5"channel. The rusting was so severe on the cross spring that the bottom leaf had the ends completely rusted off. The donor tractor has all this stuff in fair and usable condition.
ID:	141383   Click image for larger version
ID:	141384   Click image for larger version
ID:	141385   Click image for larger version
The Following 7 Users Say Thank You to Ed Bezanson For This Post:
Old 08-04-2012, 08:29:08 AM
The next 4 Pics are of the donor tractor as found in the woods in northern CT.
Front view showing tree that fell on the hood last fall during a hurricane. The tracks are in good condition but have a hole cut out of each pad[crude] so it can be used in snow. I will clean the holes up as good as I can.
The engine was taken apart years ago and much is missing but not a problem because mine is fine and complete.. Next view shows the rough condition of the driver area with air cleaner sitting in seat. lastly a rear view. This tractor has an added bonus because it has a Capistan winch mounted on the back. Not a factory install but a pretty fair job. I will probably clean up and use on mine. More pics of it when I get it out in the open.
ID:	141389   Click image for larger version
ID:	141390   Click image for larger version
ID:	141391   Click image for larger version
The Following 14 Users Say Thank You to Ed Bezanson For This Post:
Old 08-04-2012, 12:14:39 PM
Phil Johnson's Avatar
That's quite a project, Ed. I'm glad old iron doesn't rust near as bad out here in western Canada!!
Looking forward to progress pics on this one.
Old 08-04-2012, 04:52:58 PM
I am in the house for a few minutes to cool off and watch the games.
These 4 pics show the reconstruction of the tin work. I was lucky to find a 4X10 piece of 10 guage at a local metal shop. It was to be used on a fabrication for a nuclear sub but somehow it got rusty and the Navy refused it. I got it for less than half price and it is perfect for this job.
First pic shows a 4X5 piece laid out with the original piece being used as a template to cut out the new. I ground the edges of the original so that the Plasma cutter would run smooth when using it for the curves. All straight lines are cut using a long brass straight edge. By carefully moving the old piece back and forth the to compensate for the 1/8 offset of the cutting tip a pretty much exact duplicate can be cut out. The larger holes are cut out using the inside of large wachers as a guide. Once the new piece is done the old one is clamped to it and all holes are drilled out to proper size.Next pic shows new left fender side in place with the old out in front. Next shows the seat being setup and fitted and the last shows the new assemble bolted together.
ID:	141415   Click image for larger version
ID:	141416   Click image for larger version
ID:	141417   Click image for larger version
Old 08-04-2012, 10:23:27 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Thats about how rough of shape the ones I find usually are. I've passed on a few otherwise good units because of the poor condition of the under carriage. The rear sprockets look to be shot, how do you cure them when no replacements are avilable?F.J.W.
Old 08-04-2012, 11:48:29 PM
What are you talking about? Just flip the sprockets side to side, they will work great!
I think that looks to be a pretty good start actually!
rusty gas tank BobM Antique Autos and Trucks 14 07-25-2011 08:51:19 PM
Rusty Gas Tank Mark Willerick Garden Tractors / Mowers / Scooters 9 07-10-2010 09:42:50 PM
Very Rusty Engine John Carlson Antique Gas Engine Discussion 30 05-19-2009 10:21:43 AM
Rusty Treasure Mike Schweikert Garden Tractors / Mowers / Scooters 7 03-09-2009 11:54:51 PM
