Brayton Cycle Engines
this thread has 385 replies and has been viewed 75427 times
Old 06-23-2016, 01:46:47 PM
imotorhead64
Default Re: Brayton Cycle Engines
Continued improvements... new larger exhaust valve (to reduce pumping losses) also valve and ignition timing adjustments.
Old 07-02-2016, 03:49:59 AM
imotorhead64
I was reading through Clerks book "the gas, petrol and oil engine vol 2 1913 edition" and stumbled across him stating that in 1886 he went back and built another engine similar to his original compressor / expander 1878 (made from a Brayton) design. Here is a some of what Clerk had to say.
Old 07-02-2016, 04:00:25 AM
imotorhead64
Here Clerk talks about his second engine having one cylinder for compression and another for expansion... In the second engine he eliminated the reservoir to prevent explosion problems.
Here's a link to the book... it's chapter 2 titled the development of two-cycle gas engines page 184
https://books.google.com/books?id=aB...0Clerk&f=false
The Following 2 Users Say Thank You to For This Post:
  #384
Old 07-05-2016, 07:23:16 PM
imotorhead64
In addition to the "Differential" and the "Cycle" engine Atkinson also made a third and often overlooked engine which is worthy of some study and recognition... Atkinson was able to make a more conventional engine yet preserved the efficiency of having a short compression stroke and a long expansion stroke in a rather ingenious way. It sounds much like a standard 2 stroke except that the exhaust port is located at about the middle of the stroke. The exhaust is prevented from escaping by a timed valve which remains closed until the piston reaches the end of the stroke. Once the valve is opened it remains open as the piston heads toward compression letting air and exhaust escape until the port is covered. a rich fuel /air mixture is injected by a small piston pump at the start of compression. This results in a shorter compression and longer expansion stroke. The Atkinson "Utilite'" engine is described By Clerk as follows:
Old 07-05-2016, 07:27:00 PM
imotorhead64
I found this in "the Practical Engineer" from 1893 patent # for the Utilite' engine is # 2492 ( British) I've not been able to locate much information or pictures of this engine... maybe someone knows how to access the British patent system? it would be neat to see a drawing of it.
https://books.google.com/books?id=Dl...kinson&f=false
Name:	atkinson utilite engine.jpg
Old 07-05-2016, 10:17:44 PM
imotorhead64
After quite a lot of searching I finally found a drawing of Atkinson's Utilite' engine.
https://books.google.com/books?id=H0...kinson&f=false
Brayton Cycle experiment video BTurney Hit & Miss Gas Engine Discussion 3 05-20-2015 05:43:08 PM
brayton and ericsson cycle engines not stirling cycle.. imotorhead64 YouTube Old Iron Videos 0 02-12-2013 09:29:13 AM
More photos of the Fenian Ram- Brayton cycle engine PaulGray Antique Marine Engines and Outboard Motors 1 02-02-2013 06:43:50 AM
Brayton Cycle engine in a submarine PaulGray Antique Engine Photos 1 02-02-2013 06:41:45 AM
Otto cycle engines, but what about the Brayton Cycle? PaulGray Antique Engine Archives 2 09-17-2004 07:48:52 PM
