Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar Diesel 35
this thread has 9 replies and has been viewed 2860 times
Old 11-24-2013, 02:40:00 PM
JasonPayneCrawlers JasonPayneCrawlers is offline
Default Caterpillar Diesel 35
I have been able to clear the heated part of shop out just in time to start on the 35. I did the fixed the steering clutches about a year ago and I checked them yesterday and they are still free I had to locate one piston and head as they were in bad shape. The head had cracked and someone had tried to fix
Name:	photo copy 9.JPG
ID:	180237   Click image for larger version
Name:	photo copy 8.JPG
ID:	180238   Click image for larger version
Name:	photo copy 7.JPG
ID:	180239   Click image for larger version
Name:	photo copy 6.JPG
Old 11-24-2013, 11:52:55 PM
Default Re: Caterpillar Diesel 35
What's the bore& stroke? D-6, D-7, D-8 are 5 3/4 X 8. I have D-6 2H.
Old 11-24-2013, 11:54:46 PM
Tom Madden Tom Madden is offline
Diesel 35, 40, 50 and 75 are all 5 1/4 bore.
The Following User Says Thank You to Tom Madden For This Post:
Old 12-06-2013, 09:49:58 PM
I have spent the last few weeks trying to work on the 35 a bit. I rebuilt the belt pulley that I found for the machine and hand to heat handle a bit in order to bend it a 1/2'' so that it would work in the notches. We picked up the new head that I had bought in PA from machine shop yesterday. I needed it to get checked for leaks and new seats installed. The old owners looked like they tried to fix the head on the machine. I was able to find as the one that came on the machines was no good
Old 12-06-2013, 09:54:22 PM
I also bought some high strength rubber with mesh inside from McMaster Carr to make all new main clutch links
Name:	photo copy 4.jpg
ID:	181281   Click image for larger version
Name:	photo copy 2.jpg
ID:	181282   Click image for larger version
ID:	181283   Click image for larger version
The Following User Says Thank You to JasonPayneCrawlers For This Post:
Old 12-07-2013, 01:31:11 PM
19-65Port 19-65Port is offline
You can buy those clutch links new aftermarket.
Old 12-07-2013, 01:38:38 PM
chriscokid chriscokid is offline
Jim Zimmerman has them.
Old 12-07-2013, 05:28:54 PM
Cat sells them I checked. Just real pricey. I Bought rubber that is much stronger that what Cat used in the Thirty Five when it was built. I want to redo all five so it coast half this way
Old 12-08-2013, 12:16:06 PM
Terry Welch Terry Welch is offline
$134 here from Cat, Florian(spelling) in CA has them a little cheaper. If you need valve springs Cat has them for about $40 each and when we got my son's they had 40 yet in the Morton Warehouse, The little springs are $5 each from Cat.
Terry
Old 12-08-2013, 04:28:16 PM
Thanks Terry for the info
Another Caterpillar 1 cylinder diesel engine. Fred Van Hook YouTube Old Iron Videos 0 09-09-2012 09:45:47 AM
Caterpillar D17000 Diesel Electric Set J.R.Smith Vintage Diesel and Oil Engines 5 07-01-2012 04:24:12 PM
Diesel fuel in older diesel engines (bio-Diesel) Andrew Mackey Alternative Fuels 2 04-18-2008 05:22:05 PM
Loading up the Caterpillar 1Y73 Diesel ListerDiesel Generators & Electric Motors General Discussion 0 03-23-2006 02:49:42 AM
Caterpillar help Ivan Antique Engine Archives 3 03-11-2004 11:52:14 AM
