Alamo hit and miss
this thread has 49 replies and has been viewed 6089 times
Old 08-22-2014, 09:43:22 AM
Bolens Bolens is offline
Default Alamo hit and miss
I may be going to look at that Alamo hit and miss. The owner seems like a really good guy. He does not know anything about these engines. It was his Dads. Says that he used to watch it run when his Dad was around a few years ago. He told me that it had a battery so would this be some sort of buzz coil rather than a magneto? He is sending me more pictures soon.
Old 08-22-2014, 09:55:54 AM
Default Re: Alamo hit and miss
Here are some more pictures of it. It looks like the spark plug goes in the side? I see a box with a battery and what appears to be a buzz coil. If this is a hit and miss I would like to go have a look at it.
ID:	203626   Click image for larger version
ID:	203627   Click image for larger version
ID:	203628   Click image for larger version
The Following 2 Users Say Thank You to Bolens For This Post:
Old 08-22-2014, 09:58:10 AM
Here are some more pictures of it. I'm not sure if it is missing parts or not. All I know is that he said he used to watch it run about 3 years ago when his Dad was around.
ID:	203630   Click image for larger version
ID:	203631   Click image for larger version
ID:	203632   Click image for larger version
The Following User Says Thank You to Bolens For This Post:
Old 08-22-2014, 10:42:49 AM
turbo's Avatar
turbo turbo is offline
Yep it is hit and miss. But it looks like the original igniter was drilled out for a spark plug. the bracket on the push rod is for the igniter trip.
The Following User Says Thank You to turbo For This Post:
Old 08-22-2014, 11:03:58 AM
Ok that makes sense. I can see a battery and coil and spark plug in that big wooden box. I'm guessing that is how he ignited it. I think I will go have a look. He is asking $300 for everything so maybe that is ok in case I have to invest another $200 it would probably still be ok?
Old 08-22-2014, 12:29:39 PM
ChrisinEstes ChrisinEstes is offline
You better go buy that before Gilbert & I drive out there!
Chris
The Following User Says Thank You to ChrisinEstes For This Post:
Old 08-22-2014, 01:41:35 PM
Heavy Metal Heavy Metal is offline
$300 seems like a good deal to me. I'd jump on it.
The Following 2 Users Say Thank You to Heavy Metal For This Post:
Old 08-22-2014, 02:28:14 PM
Well I went out and a had a visit with the owner and his brother. Great guys and told me about when they used to watch their Dad run it two years ago before he passed at age 84.
Everything on it is free and nothing appeared to be loose. The gears did not look worn. It followed me home in the back of my truck. The tag says 2hp and made close by in Boston Mass.
I am not sure just how that spark plug and wire from the coil is supposed to ignite. Supposedly that is all the stuff that their Dad had with it. I am guessing it is missing something to time the spark? I'll get more pictures after it is unloaded from the truck. It will be a 3 man job to move it.
Old 08-22-2014, 02:34:46 PM
Randy Reysen's Avatar
Randy Reysen Randy Reysen is offline
Wow another good find! Good for you and welcome to the addiction - more will come! Also, please don't ever think of painting this engine!!!! The Lauson sure, this one no. Just my two cents. Again, excellent!
Randy
The Following User Says Thank You to Randy Reysen For This Post:
Old 08-22-2014, 02:37:34 PM
Randy
Hi Randy, why should I leave this engine as is as far as paint? It does still have a fair amount of original paint on it. I will try and gently clean it a bit and get a bunch of good pictures. I will need to figure out how to make it spark.
ALAMO Mfg. Co. and ALAMO Engine Company. Denis Rouleau Antique Gas Engine Discussion 5 07-18-2017 07:30:54 AM
Alamo 1 1/2 HP Hit and Miss PrattDave Antique Gas Engine Discussion 2 09-02-2013 06:42:50 PM
Alamo hit and miss timing geraldsteam Antique Gas Engine Discussion 15 05-22-2011 09:24:12 PM
Alamo Citrus Center, Alamo/Hidalgo, Texas survivingworldsteam Steam Stationary Engines, Traction Engines, Steam Boats 0 04-10-2006 02:26:36 PM
The Mogul Runs! Hit & Miss,Miss,Miss, Miss,Miss Dan Bogart Antique Engine Archives 7 06-24-2003 12:10:08 AM
