I think I got a WW 2 Supercharged Aircooled Lauson powered FLAME-THOWER
this thread has 16 replies and has been viewed 3065 times
Old 09-15-2014, 08:41:35 PM
mschreiber mschreiber is offline
Default I think I got a WW 2 Supercharged Aircooled Lauson powered FLAME-THOWER
I'm going to try to put this in small air cooled too.
The ringman at the sale yesterday REALLY did think it was a flamethrower.
Its a U.S. Air Force Stewart Warner model 782-Z2 portable heater. Does anyone here know anything about these, looking 4 military manuals, how to lookup military markings, Contract numbers, Etc, maybe where 2 find other help?
The lauson tag reads Model RSC 612, S/N line reads 3S31688. Its a aluminum block. What year do the lauson aircooled guys think its age is? I'm hoping for 1943 but could be 1953.
Google not much help.... Thanks 4 any help.
Carb at supercharger discharge, tubing then goes to intake port, Plumbers nitemare!!
The Following 5 Users Say Thank You to mschreiber For This Post:
Old 09-15-2014, 08:43:41 PM
Default Re: I think I got a WW 2 Supercharged Aircooled Lauson powered FLAME-THOWER
more pics.
The Following 4 Users Say Thank You to mschreiber For This Post:
Old 09-15-2014, 08:45:52 PM
more.
Shown with exhaust extensions installed.
[URL=http://s113.photobucket.com/user/wrenchguy49/media/SAM_2446_zps4e9e82b0.jpg.html]
Showing block intake tubing coming from carb with supercharger. Alot of safety wire used.
The Following 2 Users Say Thank You to mschreiber For This Post:
Old 09-15-2014, 09:34:17 PM
K-Tron K-Tron is offline
That is one of the coolest contraptions that I have ever seen! When you get it in running order, please post a video of it in action! I would absolutely love to use one of these to heat the shop in the winter
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 09-15-2014, 10:11:54 PM
I'm pretty sure that is for warming up engines in cold weather. USAF makes me think it's 1947 on, as before that it was still the air core....
The Following User Says Thank You to pegasuspinto For This Post:
Old 09-15-2014, 10:35:42 PM
I like oldstuff I like oldstuff is online now
Yup it's an engine preheater that runs on gasoline. A four engine plane used four of them. And another one to pump hot stinky air into the cockpit to warm up that area. Nice find!
Old 09-16-2014, 12:04:51 AM
Skip Landis Skip Landis is offline
I have one of those, except it has a ROOTS blower on it. I ran it several years ago, it is a hoot. I don't know much more than anyone else. skip
The Following User Says Thank You to Skip Landis For This Post:
Old 09-16-2014, 02:13:39 PM
Weezer Weezer is offline
Can I borrow it? I just want to drive around and scare the tail-gaiters until the cops make me stop.
The Following User Says Thank You to Weezer For This Post:
Old 09-17-2014, 10:08:19 PM
sure! thats a good idea around here too.
BTW, I found my fabric tubes inside the pods on top, i thought that some kinda tube was hooked on the discharge nozzle. I never really looked in there till today.
The Following User Says Thank You to mschreiber For This Post:
Old 09-18-2014, 08:32:10 AM
RLee's Avatar
RLee RLee is offline
Like I tell the wife when I get home, I don't know what it is, but by gummy I won the bid!
Nice pickup Mike, hope you can find room on a shelf somewhere.
Richard
The Following User Says Thank You to RLee For This Post:
Old 09-18-2014, 02:28:59 PM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
I had read these were used on PBY's and other non pressurized aircraft- thus the need for a supercharger.
I've seen pictures of a few of these but you've provided us with better then I've seen before. Thanks Mike.
Pretty cool find.
[I]My Photos
The Following User Says Thank You to Craig DeShong For This Post:
Old 09-18-2014, 11:00:18 PM
Fifty7ChevyNut Fifty7ChevyNut is offline
get it running, might need it come winter when the power fails.
The Following User Says Thank You to Fifty7ChevyNut For This Post:
Old 09-19-2014, 07:14:03 AM
Some internet info i found about this. Note the guy using the handcrank heater warming up the engine of the gas powered unit.
Old 09-20-2014, 10:00:43 PM
Nope I been working on this 66kw genset this summer 4 my power when outages come along. Waiting 4 decals so i can put it away.
Old 09-20-2014, 11:10:02 PM
This is not used at altitude, it is ground support equipment. It's like a supercharger but in this case it's just a blower.
Old 09-21-2014, 05:35:18 PM
I understand that it was used on the flight line with apu's to get the big radials started.
What i don't understand the supercharging of the thing. The exhaust comes out of the block into the muffler, then tubing comes off near the bottom of the muffler toward the supercharger where the carb is with a throttle control then tubing goes into the supercharger then out of it to the intake port of the engine block. The squirrel cage blower is connected to both the engine crankshaft and the supercharger. The muffler must double as a muff and a aircleaner for the intake circuit. Thanks 4 any help.
Old 09-21-2014, 06:06:37 PM
DustyBar DustyBar is offline
The engine runs the blower. The other "carb" provides fuel to the burner cans to heat the air. Its somewhat like those construction heaters, sometimes called salamanders. The blower provides more air pressure than a fan could. They run the flexible ducts to each location the hot air is needed, perhaps two engines and the cockpit. Generally aircooled aircraft engines use quite heavy oil, often 50w, and it needs a lot of preheating before the starter can turn that engine over.
I think I got a WW 2 Supercharged Aircooled Lauson powered FLAME-THOWER mschreiber Hit & Miss Gas Engine Discussion 13 05-09-2016 08:40:41 PM
Slide Valve Flame Ignition and relight flame in action Wayne Grenning Hit & Miss Gas Engine Discussion 28 04-24-2012 02:06:04 AM
Besides Briggs, Lauson & Wisconsin who built aircooled inboards? mschreiber Small Air Cooled Gasoline Engines 3 08-14-2011 08:37:23 PM
Finally, Does anyone know about a Cumingham or Lauson aircooled? JimS Small Air Cooled Gasoline Engines 5 07-06-2006 10:34:41 AM
Lauson Aircooled Info Alan James Antique Engine Archives 0 04-23-2002 11:37:28 AM
