Onan Generators Restoring, operating and maintaining vintage Onan generators. |
Onan Start Relay - One Size Fits Allthis thread has 46 replies and has been viewed 4546 times
Yes, a Ford relay WILL work on an Onan... if that Ford relay is a Ford Part Number SW220 or an AMC Part Number 3227812 or a Chrysler Part Number CH 2336 or a Delco Part Number 1114206
The SW220 has an isolated coil, meaning that the relay's pull-in coil is not internally connected, so it can be used on any Onan, regardless of how the OEM relay is internally wired, because the coil in the SW220 terminates at the relay's two smaller terminals, and is not internally connected to either of the larger switched terminals. Connect one small coil terminal to the relay's large terminal that's connected to battery +, and the relay will close when the other small coil terminal is grounded to start. Ground one of the small coil terminals with a jumper under a mounting bracket bolt and the relay will close when the opposite small coil terminal is connected to battery + to start. |
The Following 10 Users Say Thank You to lokay5 For This Post:
Sponsored Links |
That's cool. I found them for 13.99 to 28 bucks. Onan solenoids are about 25 to 35 shipped. Good info if your in a pinch and don't have a spare
The Following User Says Thank You to yellowlister For This Post:
I beg to differ . Onan PN 307-0845 connot be replaced with a 4 terminal device. The I terminal is needed as an isolated source of 12V. Here is a link.
Jack Hottel http://www.smokstak.com/forum/showth...d+for+307-0845 |
The Following User Says Thank You to Jack Hottel For This Post:
Jeep used a ford type solenoid that had an isolated coil plus an "I" terminal as well. 5 terminals total
Napa ST-83 is also a 5 terminal unit, ~$18 locally. This is from a Jeep/AMC application.
![]() Quote:
"From what I have read (and verified by the pictures), the solenoid has an insulated case. The coil is always hooked to 12V+ though the large battery input terminal on the left. It is activated by the small S terminal when 12V- is applied. The I terminal becomes 12V+ during crank through the copper foil shown in the picture." The large terminal that's connected to the start winding goes positive on crank. Why have a separate terminal? ![]() |
"I" terminal is generally used for sisson choke equipped models.
![]() Quote:
![]() I cheated. I have a Cole-Hersee catalog that shows the internal wiring of each solenoid. The12V relay with an isolated coil is Cole-Hersee number 24023 I crossed 24023 on line and got all the interchanges. There are more, too. LOTS more. Just type in Ford SW220 or Cole-Hersee 24023. Quote:
![]() If I remember correctly, the "I" was "Ignition". It bypassed the ballast resistor and supplied 12V to the coil for a hotter spark when cranking. |
The Following 2 Users Say Thank You to lokay5 For This Post:
Backfeed would keep choke on.
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Onan 5.0 BGA-3cr 16004c need help with start/stop relay wiring | nastynotch347 | Onan Generators | 22 | 07-15-2016 03:00:32 PM |
Onan 6.5NH relay? | wvhylander | Onan Generators | 4 | 10-07-2014 10:12:48 PM |
12 vdc start relay mod to open vs close circuit? | sdowney717 | Magnetos, Ignition Coils and Spark Plugs | 4 | 09-07-2013 02:12:50 PM |
Onan MCCK oil drain plug size and oil pressure port size? | sdowney717 | Onan Generators | 2 | 04-17-2012 05:50:55 PM |
