Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Cletrac OC-3
this thread has 5 replies and has been viewed 1782 times
Old 03-18-2015, 05:34:47 PM
G Willikers G Willikers is online now
Default Cletrac OC-3
A buddy is having trouble with his Cletrac. For one thing, the points are burned out and he can't seem to find them locally. It is a Herc motor but he is not providing me with much detail on numbers, etc.. He sent some pix.
he mentioned something about the distributer being #1GB4010A/8H? That might be a Prestolite #.
I thought he should put a ballast resistor on it too.
Anyway, might anyone know what he needs and where they can be found.
Thanx,
RM
ID:	221206   Click image for larger version
ID:	221207   Click image for larger version
The Following 5 Users Say Thank You to G Willikers For This Post:
Old 03-18-2015, 06:39:07 PM
Default Re: Cletrac OC-3
Rick try Zimmerman Oliver Cletrac Parts In Ephrata PA.John
www.olivercletrac.com
Old 03-18-2015, 08:39:07 PM
caser,
Thanks - I have passed that along.
Old 03-18-2015, 09:32:12 PM
G That doesn't look like an original IXB Herc engine. The original uses a wico mag mounted just ahead of the Carb on the right side of the engine. There were 2 versions of some of the Herc a 3 gear[Original IXA or IXB] and a 4 gear [ timing gears up front] This looks like a 4 gear but not sure without better pics. I have owned 10 of these little crawlers and none have had a distributor on them. This engine may have come out of some other piece of Equip. like compressor or generator. The Distributor will do fine but as you say may need a good old fashioned tune up.
PS send me your address by PM so I can send the Case pics you were interested in. Just found them buried in a pile on my desk.
Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
Old 03-18-2015, 10:43:34 PM
halcon halcon is offline
Back in the 50s the distributer companys sold adapters to replace flange mount mags. some times that was cheaper than repairing the original mag.
The Following User Says Thank You to halcon For This Post:
Old 03-19-2015, 12:55:17 AM
Old Wrench Old Wrench is offline
Just a wild guess, but other bigger Hercs used a Malory distributor that could be replaced with an IAD Autolite when Malory parts were no longer available. A four hole IAD with the right drive gear might drop into that engine. Auto parts stores still have parts for them because they were used with a long shaft in flat-fender Jeeps.
may not be much of an answer, but it came at not much of a price...
The Following 2 Users Say Thank You to Old Wrench For This Post:
Cletrac. Alexbpeterson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-03-2012 05:38:40 PM
F Cletrac David Hoover Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 03-15-2012 09:34:28 AM
cletrac 20 Ihorse Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 06-08-2011 06:50:44 PM
Cletrac H Geoffrey Mark Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-29-2008 07:37:38 PM
Cletrac--K d.j.baisch Antique Engine Archives 2 06-29-2003 03:15:16 PM
