Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Gasoline Engines and Power Units
Multi-Cylinder Stationary Gasoline Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
Portable P&H arc welder
this thread has 7 replies and has been viewed 1885 times
Old 03-27-2015, 10:27:54 PM
twistedhippy twistedhippy is offline
Default Portable P&H arc welder
Hello I just bought this out of a scrap pile. I was told that it burned sticks 5 years ago. Before i got it home tried to look it up with no luck. I think it is a Chrysler Ind straight 6 230ci tag numbers IND 6-211 10345e trying to find out some info on it i saw that other welders also had 110 plugins but none on this one. I would like to know how old it is and if there is a way to get AC power off it. Any help would be great thanks
Old 03-27-2015, 10:53:10 PM
richardo38 richardo38 is offline
Default Re: portable p&h arc welder
I have the exact same welder with a pulley on the end for belt drive.
I think all you can get is 90 volts or so DC.
Old 03-28-2015, 10:37:25 AM
dkamp dkamp is offline
eMail NOT Working
Now THAT is a welder... beautiful! Put it to work!
Are you looking for a backup generator, or did you buy it to weld?
Old 03-28-2015, 12:06:55 PM
more for a generator and that cool old flathead 6
Old 03-28-2015, 12:24:57 PM
eMail NOT Working
Well, it's definitely drippin' cool. The tin 'wrap' has an art-deco streamliner train look... if it had a set of trolley trucks under it, a guy could use it as his own electric locomotive...
If I had an electric generator, or welder/generator with a similar flathead six, I'd offer a trade... 'cause I could actually USE a welder like that on occasion... but all I got right now, is a four-cyl flathead Hercules on a 208/125Y 15kw generator... ex Civil Defense.
Old 03-28-2015, 07:12:30 PM
Default Re: Portable P&H arc welder
do you have a way to hall this old girl?
Old 03-28-2015, 11:56:17 PM
eMail NOT Working
Yep... easy... Egypt it up onto a utility trailer. There's an axle under it, which would make it a little interesting, but nothing that a couple of rails to make a skid.
Old 03-29-2015, 09:37:03 PM
I like the way you think. Your art-deco look is spot on,i like the suspension springs. I dont know if you could see in the pic the 'P&H ARC WELDER' emboss on the doors, hard to see with the 'patina' ill put up a pic, one of the plate on the motor as well. If you want to come and get her i'm down to a trade, send me a message and we'll talk
why wont my portable generator power my welder? BGarrett Welding Shop 5 11-09-2011 09:22:35 PM
Depression era welder, still works good. Sell as a welder or antique? therrera Welding Shop 0 08-30-2011 10:09:54 PM
Portable German Arc Welder aoot Welding Shop 8 05-07-2011 09:35:13 AM
Making portable welder with generator? safire Welding Shop 2 02-21-2009 10:37:29 AM
Portable mig welder Chris Page Welding Shop 4 04-30-2008 11:19:26 AM
