Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Case 320 dozer
this thread has 3 replies and has been viewed 1368 times
Old 06-19-2015, 06:51:51 PM
J5 Muskeg J5 Muskeg is offline
Default Case 320 dozer
I'm looking for a supplier of pins and bushings to rebuild the track chains on my case. Serial # 3008006, any info would be appreciated. Thanks J5 Muskeg.
Old 06-25-2015, 06:44:28 PM
Default Re: Case 320 dozer
you will have to get accurate measurements and find a local pin and bushing supplier with your sizes and see if they can match something up. The 320 is part of a line of crawlers that Case bought from Ameritrac so they could get into the Construction Business. Good Luck Ed B
Old 06-26-2015, 09:19:58 PM
Thanks for the info. With the amount of 310 's around you would think some pins would be available, but everybody would sooner sell you a set of chains. The search continues.
J5 Muskeg
Old 06-26-2015, 11:21:58 PM
Heins Heins is offline
I helped a neighbor replace the pins and bushings in a small John Deere crawler a few years ago. He got new pins and bushings from an after market parts supplier. I don't know if they are still in business. A Case dealer should be able to get you pins and bushings.
Case 310D Dozer Clutch Tim Cline Antique Farm Tractors 4 10-13-2017 01:06:09 PM
looking for old dozer Toyotabob Smokstak Down Under 0 07-18-2012 05:15:49 PM
Case 310g dozer Tim Cline Antique Farm Tractors 3 04-03-2012 08:41:35 PM
Case 310G Crawler-Dozer Tim Cline Antique Farm Tractors 1 02-29-2012 09:30:37 PM
Need Roller for my Dozer wilson Ross Dozers and Crawlers 1 12-02-2010 10:48:54 PM
