Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Cletrac 35
this thread has 6 replies and has been viewed 1134 times
Old 01-01-2016, 01:35:33 PM
Geoffrey Mark Geoffrey Mark is offline
Photo Cletrac 35
wondered if there were many cletrac 35 about , think there may have been only around 1200 built . fitted with a herculese 6 cylinder engine . couple of questions on this tractor , what is the part fitted on manifold between carbeuretor and manifold and should i get my carb reconditioned or try makeing a float hinge assembly myself . also any tips on removeing hard concert grime and grease without takeing off any paintwork , was thinking of leaveing tractor as is , what are your thoughts ?Click image for larger version
Name:	dorset county cletrac 175.jpg
Name:	dorset county cletrac 155.jpg
Name:	dorset county cletrac 178.jpg
Name:	dorset county cletrac 160.jpg
The Following 2 Users Say Thank You to Geoffrey Mark For This Post:
Old 01-01-2016, 01:44:17 PM
Travis Travis is offline
Default Re: cletrac 35
Honestly I don't even know if I would touch it, you only get that nice old look once.
Just my 2 cents...
The Following 2 Users Say Thank You to Travis For This Post:
Old 01-01-2016, 02:20:26 PM
Junkologist's Avatar
Images: 160
Looks like a Handy governor between your carb and manifold.
Mike
SmokStak member #146
Old 01-01-2016, 02:33:16 PM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Images: 4
Some parts are still to be had for those old Hercs. The device you show on the manifold looks to be some sort of rev limiter, does it have a throttle plate in it or has that been removed?. Does the carb have a throttle valve plate in it? Some times they would use a separate throttle valve above the carb to put the tractor in full idle when the motor wasn't equipped with a variable speed governor. In other words the governor only controlled the high RPM, the upper valve would be used to manually control the lower RPMs. As cruddy as that engine looks at the lifter covers you will need to drop the oil pan and clean it up thoroughly and check the bottom end bearings. Be real careful with the mains as they are only centered on the block by the bolts and they are difficult to get centered while tightening. If not right you won't carry oil pressure. We use a liberal coating of grease on the journal when final tightening to center the cap. Then snug the bolts and strike the cap on the top between the bolts a few times to spring it into center. Should do the trick then torque to specs.
Old 01-01-2016, 08:19:23 PM
Contact Landis at Zimmerman Cletrac-Oliver for any information on this unit. He can help with answer any question or parts needs. He advertises in all the tractor mags. He is out of Ephrata, PA Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
Old 01-02-2016, 02:04:57 PM
Default Re: Cletrac 35
Zimmermans is olivercletrac.com...
You'll also want to join other owners at cletrac.org; someone there may be running a registry...
The Following User Says Thank You to Bud Tierney For This Post:
Old 01-02-2016, 09:28:28 PM
GADavis GADavis is offline
The thing is a Hoof Velocity Governor. Used on lot of gasoline powered big trucks in the 40's and 50's. When the air velocity got greater than the set spring tension it would close off and restrict the intake mixture flow.
The Following User Says Thank You to GADavis For This Post:
Cletrac HG 68 d21smith Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 09-09-2017 12:29:35 PM
Cletrac W ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 06-06-2014 03:18:20 PM
cletrac 20 Ihorse Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 06-08-2011 06:50:44 PM
Cletrac H Geoffrey Mark Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-29-2008 07:37:38 PM
Cletrac--K d.j.baisch Antique Engine Archives 2 06-29-2003 03:15:16 PM
