Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Ru -D6 dozer oil switch
this thread has 4 replies and has been viewed 851 times
Old 01-02-2016, 04:53:35 AM
Johnredpwr Johnredpwr is offline
Default Ru -D6 dozer oil switch
Why does the Ru d6 dozer need an oil switch and why does this tractor have the 2 wires going to the alternator.I was wondering if it was used to energize the alternator? Can I just use a manual switch for that since it has no ignition switch.Someone else took it off and I am trying to get it figured out.
It has a delco remy alternator .
Old 01-02-2016, 09:16:51 AM
Default Re: Ru -D6 dozer oil switch
Most likely the oil pressure switch completes the circuit for the alternator. It is a fairly popular conversion for older diesel farm tractors.
Old 01-02-2016, 02:06:07 PM
I believe its used to energize the alternator.
Old 01-02-2016, 09:24:18 PM
Then when the engine is shut off the oil pressure drops opening the points and this opens the circuit so that the battery( s) do not run down when the engine is not running. Like I said popular on old farm diesel tractors that have no ignition switch or no need for one.
The Following User Says Thank You to John Schwiebert For This Post:
Old 01-03-2016, 03:10:32 AM
This diagram helped me re wire it since I was not the person who took it apart on the delco remy alternator.
BGA wiring questions, remote switch wires identification, bad rocker switch? shadow44 Onan Generators 5 06-30-2015 02:14:58 PM
Onan MDJF stops released start switch Centrifugal Switch Problem Chuck711 Onan Generators 10 01-29-2015 03:22:11 PM
Caterpillar D4 Dozer Value M&WJOE Dozers and Crawlers 3 06-19-2014 09:50:34 AM
Emergency stop switch kicks out when i push start switch hurdy Onan Generators 9 08-29-2012 07:50:51 AM
looking for old dozer Toyotabob Smokstak Down Under 0 07-18-2012 05:15:49 PM
