Otto & Langen
this thread has 75 replies and has been viewed 12002 times
Old 01-16-2016, 09:54:37 PM
Default Otto & Langen
We are doing a cosmetic restoration on our Otto & Langen at Rough and Tumble. I thought that people would like to see the engine taken to pieces.
ID:	243925   Click image for larger version
ID:	243926   Click image for larger version
ID:	243927   Click image for larger version
Old 01-16-2016, 09:58:03 PM
Default Re: Otto & Langen
4 more pictures.
ID:	243929   Click image for larger version
ID:	243930   Click image for larger version
ID:	243931   Click image for larger version
Old 01-16-2016, 10:08:11 PM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Bill it is great to see this getting redone! I sure hope you don't plan to repaint it green!
The Following 2 Users Say Thank You to Keven Withers For This Post:
Old 01-16-2016, 10:51:03 PM
LCJudge LCJudge is offline
Keven's right. Paint it Allis Chalmers orange!..........
Great to see the photos of the engine in pieces. Take plenty of photos, then take some more.
Thanks for sharing.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 01-16-2016, 11:43:42 PM
How about red white and blue like a lot of engines restored in the 1970's. Actually we are going with brown to match Greg Johnson's 2 HP Deutz slide valve engine. We are also going to use linseed oil based paint which is what it would have had on it originally.
The Following 9 Users Say Thank You to Bill Hazzard For This Post:
Old 01-17-2016, 12:38:32 AM
Lester Bowman Lester Bowman is offline
I'd strip off all that nasty and leave it.
The Following User Says Thank You to Lester Bowman For This Post:
Old 01-17-2016, 05:00:53 PM
Here are some more photos of the disassembly.
Name:	photo 1 (2).jpg
ID:	243987   Click image for larger version
ID:	243988   Click image for larger version
Name:	photo 2 (1).jpg
ID:	243989   Click image for larger version
Name:	photo 1 (1).jpg
The Following 11 Users Say Thank You to Bill Hazzard For This Post:
Old 01-17-2016, 05:03:01 PM
Four more.
Name:	photo 2 (2).jpg
ID:	243996   Click image for larger version
ID:	243997   Click image for larger version
Name:	photo 3 (1).jpg
ID:	243998   Click image for larger version
Name:	photo 3 (2).jpg
Old 01-17-2016, 05:05:11 PM
Last four.
ID:	244000   Click image for larger version
Name:	photo 4 (1).jpg
ID:	244001   Click image for larger version
Name:	photo 4 (2).jpg
ID:	244002   Click image for larger version
Old 01-17-2016, 05:44:43 PM
Bill, is this the first time the OL has been fully disassembled since John Wilcox reworked it in Willock's shop in the 70's?
Tommy Turner
Old 01-17-2016, 05:49:02 PM
Wayne Timms Wayne Timms is offline
Thanks for posting these photos Bill.
Interesting to see that the water jacket plate on the underneath of the engine bolts to the cylinder head with a single fastener. This is the same as the later engines.
The fluted column in the Powerhouse Museum in Australia - its water jacket plate is held on with a number of bolts running in a circular pattern.
Regards,
Wayne
www.bluefuel-whitesmoke.com
The Following 4 Users Say Thank You to Wayne Timms For This Post:
Old 01-17-2016, 07:51:32 PM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
Any thoughts of straightening the flywheel shaft to take that nasty wobble out?
Old 01-17-2016, 08:02:09 PM
Tommy,
Yes this is the first time it has been apart since it was painted, I believe it was around 1978.
Brian, Yes we are going to straighten the main shaft.
Old 01-19-2016, 07:28:58 PM
Friedrich W. Busch Friedrich W. Busch is offline
Bill, should there be any leftover parts after reassembly, here are the operating instructions (as well as sales brochure) for the Deutz atmospheric engine. Should you need these documents send me a mail.
ID:	244168   Click image for larger version
The Following 11 Users Say Thank You to Friedrich W. Busch For This Post:
Old 01-20-2016, 03:04:39 PM
We got a donation of a new sub base casting that was patterned off of serial number 1 O&L at the Deutz Museum. I mounted it to the face plate on my milling machine and faced it top and bottom and drilled the engine mounting holes.
ID:	244236   Click image for larger version
ID:	244237   Click image for larger version
ID:	244238   Click image for larger version
Old 01-20-2016, 10:17:09 PM
Tom Stockton's Avatar
Tom Stockton Tom Stockton is offline
Member
That's one unusual horizontal mill, Bill!
Tom Stockton
Old 02-08-2016, 08:23:21 PM
I made some more progress on the O&L. I got the main shaft much straighter than it was. It had a total runout of .110" and I got it down to only .010" total runout. The flywheel should run a lot truer now. I did have to heat the shaft some as my little 12 ton press could not bend the shaft cold.
ID:	245897   Click image for larger version
ID:	245898   Click image for larger version
Old 02-08-2016, 08:26:36 PM
I did some polishing to the clutch halves, pulley and the gear.
ID:	245902   Click image for larger version
ID:	245903   Click image for larger version
Old 02-08-2016, 08:37:33 PM
Thanks to Wayne Grenning, we now know the full history of the engine from day one. Wayne has a contact that knows a retired corporate historian of the Deutz company and from him we have learned that engine number 10, which is our engine, was shipped from the factory on February 15th 1868 to John A Roebling. From Roebling it went to the Stevens institute in 1873. William Willock bought the engine from Stevens in 1953 and it was then donated to Rough and Tumble upon Willock's death.
Old 02-20-2016, 09:16:52 PM
I got some more work done on the Otto & Langen. I first scraped one side of the slide valve flat and then machined off a few thousandths off as the slide was tapered by about .005" then I scraped the other side flat and then re scraped the first side because when I machined the surface the first side curved down. Then I scraped the cover of the exhaust slide.
ID:	247029   Click image for larger version
ID:	247030   Click image for larger version
ID:	247031   Click image for larger version
Looking for Otto & Langen plans Jim K Scale Model Engineering 4 08-21-2010 12:06:00 AM
Otto Langen Fred Van Hook Scale Model Engineering 0 10-02-2008 05:07:26 AM
Otto-langen James L Johnson Hit & Miss Gas Engine Discussion 27 03-21-2008 10:01:05 PM
Otto Langen auction Wayne Grenning Antique Engine Archives 11 12-02-2002 11:44:36 PM
Otto Langen Patrick M Livingstone Antique Engine Archives 0 10-06-2001 09:32:14 AM
