Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Need a John Deere MC Final Drive
this thread has 7 replies and has been viewed 1026 times
Old 01-21-2016, 10:13:02 PM
con-rad con-rad is offline
Default Need a John Deere MC Final Drive
Hey all,
I busted the case of the left side final drive on my MC while i was pushing dirt. I've been searching craigslist and ebay for a final to no avail, does anyone know of a good JD-specific parts website/boneyard?
thanks,
connor
Old 01-21-2016, 10:32:24 PM
lukeste lukeste is offline
Images: 1
Default Re: Need a John Deere MC Final Drive
Sent u a message....
Old 01-22-2016, 12:13:05 AM
I have a MC to restore with one final drive not working. I think that they were light and not strong like a caterpillar. Good luck.
Old 01-22-2016, 05:22:36 PM
they're known to have weak finals. If you look at the newer models of JD crawlers like the 440, 1010 etc you can see lots of re-enforcing webbing in the casting.
conrad
The Following User Says Thank You to con-rad For This Post:
Old 01-22-2016, 08:27:07 PM
Conrad Check with Karl Hansen since I think he had one or knew of one. Ed B
Old 01-24-2016, 04:37:38 PM
Charlie1925 Charlie1925 is offline
Con-rad; I had the same thing happen to me about 30 years ago on that same MC type tractor. What I did was take it all apart and lay the casting on the welding table, Grind the cracks and broken edges, put back together and clamp real good together and to welding table, Do some preheat with gas thorch and weld about one inch at a time in maybe three places then wait about 1/2 Hr. do some more preheat and weld about one In. In about three more places. Do this till all is welded, Overlap a bit on the welds. Take your time, Don`t get in hurry, It mite take 1/2 a day to get this done, Then turn part over and start over again, Grind joints, Take your time, Another 1/2 day or so. this time between welding , Put a couple of heat lamps on the part, real close, move lamps, do some welding. Do this till all is welded, kept the heatlamps on for 2 to 3 Hr. then back off a bit. then wait over night with heat on ,let cool very slowly and grind smooth on inside where needed, I would not grind outside much. Use a good rod and penetrate good. Have fun. Roger Weinhold AKA Charlie 1925 Check my profile
The Following User Says Thank You to Charlie1925 For This Post:
Old 01-24-2016, 10:50:28 PM
Thanks Ed, i'll see what he has.
Do you guys know how to take the hub/sprocket off of the drive shaft? i've been cranking on it with a puller and hitting it with a torch and beating it with a hammer to no avail. Judging by my parts manual, there shouldn't be anything else holding it on...
thanks,
conrad
Old 01-25-2016, 12:30:20 AM
Con-rad; You just came in contact with a 4 letter word . ( RUST ) or that other word witch is ( Intergrandalar carrostion ). That tractor is about 50 + or - years old , It`s had a long time to do what ever it did. About all one can do is what you are doing, plus some good penitrating oil like (Kraoil )
l don`t know what the factor is between years rusting and getting something lose, Hopefully only a day or two, Kept the puller on with heat and oil and wait . Good luck.
John Deere 70 Sarter Drive Need Advice roy cowan1912 Antique Farm Tractors 6 08-16-2015 04:42:01 PM
John Deere & John Deere Bain horse drawn mowers Amosalmo Horse Drawn Equipment 4 05-18-2012 11:35:01 AM
John Deere A and John Deere R For Sale (Stuck in the snow!) Gary Biewer Antique Farm Tractors 11 01-25-2011 06:33:52 PM
Mogul 8-16 final drive sprocket Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-22-2010 02:34:42 PM
John Deere Model # 809 drive unit Bob Johnson Antique Gas Engine Discussion 1 03-17-2009 12:23:42 PM
