Picked up a 1926 Fordson the other day
this thread has 44 replies and has been viewed 4721 times
Old 04-25-2016, 07:18:11 PM
Default Re: Picked up a 1926 Fordson the other day
These are pics of the differences between pistons. Pic No 1 shows close-up of a curved top piston. Pic No 2 is a better view of the 2 profiles side by side. The flat top on left has a bevel around the edges while the one on the left is clearly curved. I pulled these out of some old boxes of parts and think the left one is a Model F piston and the one on the right is from an English N. Steve or Butch may correct me on this since I haven't done a rebuild in 7-8 years and my memory doesn't work that far back Ed B
ID:	252321   Click image for larger version
The Following 3 Users Say Thank You to Ed Bezanson For This Post:
Old 04-28-2016, 08:34:31 PM
Nate Bolduc Nate Bolduc is online now
I took a better video of the Fordson today. I also hooked up the governor and was quite happy to see that it works. The clutch is working much better now too.
The Following 11 Users Say Thank You to Nate Bolduc For This Post:
  #43
Old 04-28-2016, 10:43:12 PM
Thumbs up Re: Picked up a 1926 Fordson the other day
Y're doin' some nice werk there Nate........
Old 04-29-2016, 07:52:53 AM
Thanks Craig! Just have to take it one step at a time.
The Following User Says Thank You to Nate Bolduc For This Post:
  #45
Old 04-29-2016, 01:43:22 PM
Steve Welker Steve Welker is offline
Nate, sounds great! This one must have some pretty good rings and valves. A Fordson that is good internally has a little bit of a 'bark' to the exhaust note, and I hear it on this one. While a worn out one may run, they sound more like an air leak.
One quick tip. Do not run it with the clutch locked down for super long extended periods of time. A Fordson does not have a throwout bearing, just a bronze horseshoe that rubs against the clutch. While it is lubed by the engine oil, it can still get overheated or wear away.
-Steve
The Following 4 Users Say Thank You to Steve Welker For This Post:
1926 REO truck Russ Hamm Antique Autos and Trucks 17 07-27-2018 03:28:46 PM
1926 Pontiac Richard Sturdy Antique Autos and Trucks 4 06-05-2014 07:34:26 PM
Old Iron Lovers Will Love This. 1926 Fordson Snow Motor Steve Sewell Hit & Miss Gas Engine Discussion 5 06-11-2013 01:01:18 AM
Associated Hired Man - 2 1/2hp 1926 LarrapMan Hit & Miss Gas Engine Discussion 35 12-04-2012 01:08:23 PM
1926? gen. set V4 WC gas Bob Stover Generators & Electric Motors General Discussion 0 03-22-2004 06:02:15 PM
