Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Oliver OC3 repower
this thread has 9 replies and has been viewed 1126 times
Old 09-05-2016, 05:17:38 PM
cb1 cb1 is offline
Default Oliver OC3 repower
Hello all,
Starting my new project. Make it work now, paint in the winter. In the shop.
The motor is just sitting on it now. Will be moved back about 18 inches, and the tank will be lowered 5 inches or removed.
The original Hercules's crankshaft walked right through the thrust bearing and into the block. Junk.
The new motor runs currently.
Thanks for looking and will update as I go.
cb1
ID:	262032   Click image for larger version
The Following 5 Users Say Thank You to cb1 For This Post:
Old 09-05-2016, 07:33:28 PM
PFT's Avatar
PFT PFT is offline
Images: 31
Default Re: Oliver OC3 repower
Does the output shaft on the V4 turn the correct way? Some of those clutch and gear box units reverse the rotation to mimic tractor PTO so the engine replaces a tractor PTO on equipment. Just a thought so you don't end up going backwards when you want to go forward.
PT
Old 09-05-2016, 11:24:16 PM
cb1 cb1 is offline
Yes, the gear reduction is a 2 to 1 and it does goes the opposite direction, however, I took that off and the straight clutch housing from the Hercules bolts right up. Will need to make one of the clutch setups work. Not sure yet, which will be the easier. I will post picture of the Hercules clutch housing when I a chance.
Thanks,
cb1
The Following 3 Users Say Thank You to cb1 For This Post:
Old 09-06-2016, 05:23:58 PM
cb1 cb1 is offline
This is the new (Hercules) clutch housing setup vs the gear reduction (Wisconsin). The Wisconsin is a over-center and the Hercules is a push to release style.
Either one will be with a hand lever. I had that setup on my old Allis HD10 and liked it a lot.
cb1
ID:	262155   Click image for larger version
Old 09-07-2016, 08:34:03 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
What model Wisconsin is that?
Patrick
Old 09-07-2016, 10:39:45 PM
cb1 cb1 is offline
1949 vintage VP4. Yes, the big dog. It has a mag, but someone added an electric stater, so that was nice.
cb1
I really don't know much about them, but learning fast..
Old 09-07-2016, 10:49:50 PM
cb1 cb1 is offline
Anyone know what the spec number means would be very helpful?
cb1
ID:	262360   Click image for larger version
Old 09-07-2016, 11:19:06 PM
Heins Heins is offline
If you are going to repower it, why don't you use a better engine than the V-4 Wisconsin. Like a 4 cylinder CASE gas off a swather or a 108 Perkins Diesel.
Old 09-07-2016, 11:39:38 PM
Having owned 8-10 of these I have seen many different power units including and early Volvo and a Mustang II OHC 4 Cyl. They all work because the Trans is separate from the engine. I just wonder how to hook the Wis. Clutch to the Oliver input. Good luck on your conversion and keep the Pictures coming as you move forward. Ed B
Old 09-07-2016, 11:54:45 PM
cb1 cb1 is offline
First, because I have it. And it runs. And its air cooled. Simplify everything.
I have a OC4 that has a good engine and is complete that matches my Super 55, that I plan on making a small dozer out of. This OC3 will be for pulling my Adam #4 grader.
Second, the original OC3 bell bolts right up to the Wisconsin. Just need to figure out the internals. And then a driveshaft, jack-shaft or chain drive.
Thanks,
cb1
The Following 2 Users Say Thank You to cb1 For This Post:
McCormick WK-40 FBB to Red Diamond RePower Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 161 12-29-2017 11:34:59 PM
Twin City 20-35 4 cyl to MM 6 cyl RePower Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 58 07-24-2017 12:28:40 AM
Oliver 77 & Oliver Super 77 Parts Book / Manual TractorDom Service Manual Scans 2 06-19-2017 08:09:49 AM
Cockshutt 40 tractor repower ChadYelland Antique Farm Tractors 2 07-18-2015 10:07:58 AM
Gravely repower help teachingscience Garden Tractors / Mowers / Scooters 1 05-05-2014 09:50:14 AM
